Garage Door Opener Having Trouble Closing Door - Electrical - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 01:58 PM   #1
Garage door opener having trouble closing door
Hi all,
My garage door opener is only closing halfway and then opens again. It does this regardless of whether the opener is attached the door or not (both under load and not).
I noticed that the gear that engages the chain is sitting at an angle..is this a major issue? There's what looks to be a washer that's sitting off at an angle and the pole going up from the motor is at an angle as well.
Is there any simple fix besides replacing the opener or is it even possible for a fairly competent but non-professional like myself to fix? Any idea as to what might have caused this?
Thanks in advance
camelian is offline   Reply With Quote
Old 08-07-2012, 02:27 PM   #2
Rewards Points: 1,566
It looks like the bearing for your drive shaft has given up the ghost. One of these days it will likely stop for good. Make sure you know how to open/close your door by disengaging the traveler.
How old is the opener? If 10+, it likely is time for new.
You may be able to get parts for it but that all depends on your drive, abilities, and parts availability.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
camelian (08-09-2012)
Old 08-07-2012, 02:33 PM   #3
Opener was made in 5/29/06 so I don't suspect it to be older than 6 years. I thought these guys had longer life expectancies..especially a Chamberlain Lift Master.
So there's not much hope for this guy huh? Is it even worth trying to fix vs buying a new one? It's weird that it still runs for about half the length of the track but then just reverses by itself, both under load and not under load
Old 08-07-2012, 02:39 PM   #4
Rewards Points: 13,274
I'd remove the chain and see if the sprockets loose or the bearings move when you try to move it from side to side.
Old 08-07-2012, 03:47 PM   #5
Take a look at the chain sprocket when it is opening/closing and see if you see it get hung up/change position etc...
If not, you could try adjusting the up/down force and it might fix it. Usually a little screw on the side of the opener that you turn about 1/8th of a turn at a time to see if it improves.
Old 08-08-2012, 10:01 AM   #6
Here is a clip of what it's doing: http://www.youtube.com/watch?v=-d2Yv-d0kto
I took off the chain and the sprocket assembly on the opener moves up and down about 1mm. When it's at the down position, it doesn't really move side to side. When I lift it up, it moves side to side. It usually operates with the assembly lifted up and leaning towards the outside.
Is this just a matter of replacing the gear and sprocket assembly? (http://www.garagedooropenerparts.net/geandspas1.html)
I have home warranty good for another month with a $60 service call fee but after I replaced the chain it's working again..though the sprocket is still operating at an angle and I hear some gear skipping.
Old 08-08-2012, 12:37 PM   #7
Rewards Points: 746
It may not be the opener - yet. Check the door operation first.
Disconnect the opener from the door with the pull.
Then, open and close the door manually. How does it seem to work? It should go up/down smoothly and stop in any position.
AandPDan is offline   Reply With Quote
The Following 2 Users Say Thank You to AandPDan For This Useful Post:
bob22 (08-08-2012), camelian (08-09-2012)
Old 08-08-2012, 10:35 PM   #8
firehawkmph's Avatar
Rewards Points: 1,822
Check you door operation manually like Dan suggested. If it works smoothly then focus on the opener. That shaft has too much sideplay. I don't know offhand if there is a replaceable bushing on your opener. If there is, get one. Try your old shaft in there first and see if that gets rid of the side play. Your gears don't look to be worn much at all.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 08-08-2012, 10:53 PM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'd check the photo eyes. Not only are they aligned correctly, but that they are secure and not vibrating.
Old 08-09-2012, 09:55 AM   #10
The door does seem to be a little heavy coming down. It will come down on its own starting about halfway down. Maybe that led to premature wear on the bushing? Luckily it looks like this opener has a fairly easily replaceable gear and sprocket assembly. I'm going to try replacing it since I found a replacement kit for only $26 on eBay
The sensors are mounted securely and working as they should
Old 08-09-2012, 10:03 AM   #11
Rewards Points: 746
You need to adjust the tension. The springs should balance the load of the door so that it stops and stays where you leave it.
If it's tension springs it's not that hard. If it's a torsion spring, call someone in.
Garage Door Opener Help jwysocki General DIY Discussions 1 04-10-2011 05:28 PM
Garage Door Repair Tip doortodoor Windows and Doors 0 03-15-2011 09:05 AM
Garage Door Opener Help chard General DIY Discussions 5 02-03-2010 06:06 PM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 08:22 AM
