Old 03-04-2013, 09:15 AM   #1
garage door
My first garage and I love it.
No idea how old the motor is.
Last night hit the remote on the car and the door rose about 3 ft and stopped. I was perplexed. I hit it again to close it and tried again and it opened all the way.
If the door ever stopped working is there a way to open it? Does the motor need any kind of maintenance. Would I call an electrician or find a garage door company?
thanks
Startingover is offline   Reply With Quote
Old 03-04-2013, 09:23 AM   #2
joed's Avatar
garage door
The open should have a short rope where the trolley connects to the door. This is the release to free the door from the trolley so it can be opened manually. The first test you should do is release the door and try it manually. It should open with minimal force. If it functions properly then some of the adjustments on the opener might need to be tweeked.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
Startingover (03-04-2013)
Old 03-04-2013, 09:28 AM   #3
garage door
With the door down give that piece of rope with the little handle on it a yank where the door and the middle rail attach. hat will reliece it.
Now try to open and close the door, it should be able to be lifted with one hand. It should also be able to be stoped and place and it will stay in place.
If there's to much resistance the door has a setting causing it to stop.
The springs may need adjusting or the rollers may just need some lub.
If the door ever stopped working is there a way to open it? Just pull the rope where the top of the door connects to the track. Does the motor need any kind of maintenance. Would I call an electrician or find a garage door company?
An over head door company is the one to call.
thanks
http://www.geniedoor.com/troubleshooting-guides
garage door won't go down Kela82 Building & Construction 7 02-21-2013 12:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
How to find a garage door dealer meburdick Building & Construction 5 06-28-2011 09:29 PM
Garage Door Assistance dukes32 General Discussion 2 06-15-2011 01:11 PM
Old Genie Garage Door Opener cmgith General Discussion 3 11-27-2006 09:53 PM
