Garage Disconnect Question - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 02:33 AM   #1
Jack of All Trades
Garage Disconnect question
I have a detached garage with a single 20A line running underground to the garage, my question is do I need to have a disconnect inside the garage since it's detached? And does it have to be an actual purpose-built disconnect switch or would a double-pole 20A switch do just as well? (cut off both hot and neutral) Already plan to wire in a GFCI as first device to protect down-stream, could the GFCI act as a disconnect?
Thanks in advance!
DoctorWho is offline   Reply With Quote
Old 07-11-2011, 06:52 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
A single pole switch is fine, you do not have to cut off the neutral.
Coastal South Carolina
Old 07-11-2011, 10:29 AM   #3
Jack of All Trades
Thanks rj, that's all I needed to know!
basement with garage insulation question WS6transAm General DIY Discussions 7 01-21-2011 06:15 PM
question about wiring basement with garage panel 1acman Electrical 4 01-19-2011 11:44 AM
Garage Door Question wikkie650 Building & Construction 8 12-02-2010 03:57 PM
Thoughts on wiring new attached garage/hallway Mi Feller Electrical 45 06-18-2010 06:47 PM
Carport to Garage: Fire barrier question Grommet Remodeling 2 03-28-2008 04:18 PM
