Garage/deck Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2008, 07:19 PM   #1
Rewards Points: 150
garage/deck wiring
Now that my deck behind my garage is complete, it's time to rewire the garage and put some general purpose recepticals and lghting out back.
I have a 20amp gfci breaker that I can use. Will it be OK to use this to protect both the garage and deck electricals?
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 08-12-2008, 08:44 PM   #2
Rewards Points: 6,652
This answer is coming from a non-electrician, but personally if it was me, I would use a Separate circuit for the Deck & Garage, especially if you have the GD opener on the same circuit. No need to have the Circuit blow, and then have to reset every time because you overloaded the circuit for that awesome party you planned.
Old 08-12-2008, 11:26 PM   #3
#14 gauge cable must be protected by a 15 amp breaker.
A 20 amp breaker would be used with #12 gauge wire.
Old 08-13-2008, 01:13 AM   #4
Rewards Points: 150
Thank you for your responses. The GD openers are on a separate circuit and I do know what wire to use with what breaker.
Warren Zevon
Old 08-13-2008, 02:58 AM   #5
" Euro " electrician
frenchelectrican's Avatar
Normally It will be wiser to keep the lighting circuit seprated from the deck/ garage recepectale circuit and depending how big the deck you build you may end up need two circuits there.
Merci,Marc
Old 08-13-2008, 08:22 AM   #6
Rewards Points: 150
Thanks,
I know that the garage and outdoor plug ins must be gfci protected, but what about the lighting ??
Warren Zevon
Old 08-13-2008, 08:52 AM   #7
Does not need protected, but if you want, and able to stay within load Calc's, you could keep it on the other circuit. You will have to keep with #12 all the way.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Electrical problem, bad wiring? mumblemouth Electrical 10 08-09-2008 12:52 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
