Garage Breaker Keeps Tripping - Electrical - DIY Chatroom Home Improvement Forum
Old 07-18-2012, 12:28 PM   #1
Garage breaker keeps tripping
Hello,
For the past few weeks I've been dealing with my garage breaker keeps tripping. The garage is not connected to the house. I will go and flip the breaker back on, and it will be fine for an hour or so, and i will check on it again and it will be tripped. There's a small panel in the garage with 3 breakers that aren't tripping and are on as normal, the one that trips is the breaker that is in the main panel in the house. That breaker powers the outside garage light, and the garage door opener (Craftsman 1/2 HP).
A couple of weeks ago, I went out and unplugged the garage door opener for a couple of minutes, hit a green button on the back of the opener (not even sure what it is), plugged the garage door opener back in, and went and turned the breaker back on and it worked fine for over a week, and now just a couple days ago its still tripping non stop.
I cant think of anything that is triggering this, and have been keeping an eye on everything to try and figure it out, but all I can think is that the garage door motor is bad, or the breaker needs replaced.
Thanks for your help, this is so damn frustrating.
breaker by rhanson85, on Flickr
The bottom switch on that breaker is for the oil heater, the top one is the one that keeps tripping. The oil one hasnt tripped.
rhanson85 is offline   Reply With Quote
Old 07-18-2012, 02:35 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,984
It could be as simple as a bad breaker.
Easy way to figure out....swap the wires with a similar sized breaker. If the problem follows the wire....you have some troublshooting to do.....if the same breaker keeps triping....replace it.
Old 07-18-2012, 02:49 PM   #3
Rewards Points: 826
If it is garage door opener related (a big if) it could be spring are out of adjustment on the door. The opener is designed to open a well balanced door (springs balance the weight of the door). Openers will strain if the springs have stretched and are no longer doing their job. Motor current will rise and that could trip a breaker. If you can't easily open the door by hand (with opener disengaged) then the springs need maintenance. Those springs are dangerous so I recommend a door guy and not DIY.
curiousB is online now   Reply With Quote
Old 07-18-2012, 03:14 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It could be that the underground is going bad. When it trips, has there recently been rain? That would explain why the breakers in the garage aren't tripping...(I'm not sure how you have a panel in the garage when the breaker feeding it is 20A 120V)
Old 07-18-2012, 04:41 PM   #5
biggles's Avatar
shut the garage breakers off then turn the house on on..trip? if it does it is the run out to that garage breaker panel from the tripped house one.if it doesn't trip...turn each garage breaker on one at a time.... see if that trips it...if still no trip plug the loads in "one at a time"that normally are on it there..
Old 07-19-2012, 06:24 AM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Bad wire from house to garage!
jbfan is online now   Reply With Quote
One breaker tripping another armisjam Electrical 12 03-09-2012 08:43 PM
ARC Fault breaker tripping zevo Electrical 12 09-04-2011 02:11 PM
AFCI Breaker Keeps Tripping Muinchja Electrical 30 08-25-2011 04:54 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
