Garage / Bedroom Wiring Code Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-19-2010, 05:36 PM   #1
garage / bedroom wiring code question
I need to accomplish two things, (1) run a new 20 amp circuit to our bedroom due to my wife's 1800 watt hair dryer (running on a 15 amp now), (2) provide a power source to my garage door openers. As the garage door opener is right below our bedroom, I'd like to run the new 20 amp circuit (12/2 wire) two a junction box near the openers, run it from the box to the new bedroom outlet for her hair dryer, then run wires out of the box for outlets to service the garage openers. It is very unlikely that openers and dryer will be running at the same time, so I'm not worried about overload. My question is it a code violation to have a circuit in the basement route power to an outlet on the main floor. Thanks in advance...JC
205bhamjim is offline   Reply With Quote
Old 01-19-2010, 06:13 PM   #2
A garage circuit needs to be GFCI protected
A bedroom circuit needs to be AFCI protected
So you would need an AFCI breaker on this circuit & a GFCI outlet for the garage door opener
I'm not sure if the garage door opener will cause the AFCI to kick off
Old 01-19-2010, 09:24 PM   #3
Inspector/Instructor
codeone's Avatar
This should not be a problem.
codeone is offline   Reply With Quote
Old 01-20-2010, 10:36 AM   #4
thanks guys. JC
Old 01-20-2010, 10:55 AM   #5
little more follow up on reply.
Could I just use the one standard AFCI circuit for garage and bedroom hair dryer outlet? Since the one bedroom outlet is the end of the line, I could add a GFCI outlet (as there is no water etc near by it is not really needed). Any code issues with having a circuit sharing a garage and bedroom?
Attic wiring question everyman Electrical 4 07-07-2009 10:47 AM
GFCI in detached garage question WShawn Electrical 2 08-02-2008 04:27 PM
Carport to Garage: Fire barrier question Grommet Remodeling 2 03-28-2008 05:18 PM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 06:44 AM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
