Galvanized Steel Conduit - Adhesive - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2014, 05:48 PM   #1
Hi all! I'm planning on making poles for a tarp from galvanized steel conduit. I have PVC caps that fit snugly on the ends, but I want to glue them in place. The caps will have bolts sticking through them that will go through the eyelets on the tarp. So my question is, what type of adhesive or epoxy will secure the PVC to the conduit? I see that Loctite Epoxy Plastic Bonder claims to stick to plastic, steel and aluminum, but I'm a bit skeptical.
Tommcgtx is offline   Reply With Quote
Old 06-13-2014, 06:21 PM   #2
Rewards Points: 3,396
female adapter > small nipple (enough for adapter and cap)>cap
could get a rigid cap and drill it.
Galvanized Steel Conduit - Adhesive-adapter.jpg   Galvanized Steel Conduit - Adhesive-cap.jpg
ritelec is offline   Reply With Quote
Old 06-13-2014, 07:12 PM   #3
Rob
Robpo's Avatar
Rewards Points: 826
I would go with the rigid cap and drill it, the PVC adapters are not strong.
Robpo is offline   Reply With Quote
The Following User Says Thank You to Robpo For This Useful Post:
mpoulton (06-15-2014)
Old 06-13-2014, 07:12 PM   #4
DIY staff
Rewards Points: 7,174
Epoxy glue would work----
Old 06-13-2014, 10:21 PM   #5
Msradell's Avatar
Rewards Points: 210
Definitely the best way to go!
Msradell is offline   Reply With Quote
Old 06-13-2014, 11:41 PM   #6
I'd like to use metal caps, but I really don't have a decent drill. In fact, all I have right now is a flex-shaft grinder that only takes bits up to 1/4" shank size. Anyway, this is the type of cap I want to use. It's a SCH 80 PVC cap.
Old 06-14-2014, 08:07 AM   #7
There you go,
I figured they'd probably make the pvc cap threaded.
(no need for all that adaptor stuff)
Go for it !
Old 06-14-2014, 09:07 AM   #8
Thanks everyone for your responses. Although the cap is threaded, the conduit is not. The threads make the cap fit snugly on the end of the conduit, but I'm thinking that with the tension from the tarp, and the rope I will use to stake it, it will come off. that's why I wanted to glue it somehow, and was wondering which type was best suited to gluing PVC to galvanized steel. I'm just a bit nervous about using epoxy, as I've had experiences with it not working on plastics. I'm hoping that the one I mentioned above, Loctite's Epoxy Plastic bonder will work.
Old 06-14-2014, 09:31 AM   #9
Rob
Robpo's Avatar
Rewards Points: 826
I think the only way to know is to do a test.
Old 06-14-2014, 02:29 PM   #10
So, instead of messing around with glue and doing experiments, I decided to use the old tried and true. Duct tape! Duh! I don't know why I didn't think of that first. Since the cap seats firmly on top of the conduit pole, the tape is enough to keep it from popping off.
Galvanized Steel Conduit - Adhesive-100_2410.jpg   Galvanized Steel Conduit - Adhesive-100_2411.jpg
Old 06-14-2014, 02:49 PM   #11
Rob
Robpo's Avatar
Rewards Points: 826
Looks like EMT. That will never pass code.
Tommcgtx (06-14-2014)
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 08:02 PM
Can I run several circuits through the same conduit? JeepNick Electrical 19 02-16-2012 03:47 PM
How to plug unwanted and leaking conduit? gernith General DIY Discussions 6 08-08-2010 12:09 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 05:25 PM
buried galvanized steel pipe amakarevic Plumbing 6 06-23-2009 02:15 PM
