Old 09-25-2012, 06:53 PM   #16
ffemt121's Avatar
Gable Fan Switch
Ok thanks Kevin, I will look into replacing it. I noticed when I was up there a lot of non-secured wires, should I be getting them secured to the joists also? I'm considering taking a room at a time and running a new home run for each room, just so I can relieve some of the strain on some of the 15 amp breakers
ffemt121 is offline   Reply With Quote
Old 09-25-2012, 07:47 PM   #17
Semi-Pro Electro-Geek
Gable Fan Switch
It's very common for wiring in a residential attic to not be properly secured, but it is a code violation. The required interval is every 4' (or is it 4-1/2'?), and passing through a hole drilled in framing counts as a point of attachment. I would not mess with it if it were mine, unless I were doing a lot of work up there already.
I second Kevin's opinion of that fan - it looks pretty questionable. It's also not grounded, since the metal armor of that flex conduit is not connected to the thermostat enclosure like it should be.
mpoulton is online now   Reply With Quote
Old 09-25-2012, 09:23 PM   #18
kevinp22's Avatar
Gable Fan Switch
this is a great idea. you might rewire your house before its over. i do recommend getting permits for your work.
kevinp22 is offline   Reply With Quote
Old 09-25-2012, 09:28 PM   #19
ffemt121's Avatar
Gable Fan Switch
I always do Kevin. I have learned very quickly just how tough out code enforcement folks can be
Old 09-25-2012, 09:55 PM   #20
kevinp22's Avatar
Gable Fan Switch
well then welcome to the forum
we are here to help. post your questions and pics as you go.
many pros are on this board as well as DIY like me who love this stuff
Old 09-25-2012, 10:30 PM   #21
ffemt121's Avatar
Gable Fan Switch
Thanks Kevin, I've always had pretty good luck with forums, and the people offering help. I will offer what I can, where I can.
Old 09-26-2012, 05:35 AM   #22
new guy
Gable Fan Switch
I took your first photo into PhotoShop and enhanced it to see what was in the darkness. Also rotated it 180 degrees to make it easier to look at. It seems to be the manual cutout switch. If that's a bulb shell for an indicator light, it certainly sticks out a lot. At any rate, the switch was designed to be in a switchbox with a coverplate over the front.
Brian
bclee is offline   Reply With Quote
Old 09-26-2012, 08:02 AM   #23
ffemt121's Avatar
Gable Fan Switch
I know it was meant to be in a box. The room it's in us unused and we plan on reconfiguring the walls, so rather than run it into a wall that will be demoed in a few months, I nailed a single gang new work box to the inside of the closet's door frame, up high by the corner. That way, I'm the only one in the house who can reach it. I pulled the line thru, trimmed about 24" off it, re-stripped it and put a new switch on it. Then I mounted it in the box and trimmed down a switch plate cover so it would fit properly, and cover the area around the switch. Then I used the wire staples to secure the wire to the wall in there. It's just a temporary way to try and make it a bit safer until I have the time and money replace it all
Old 09-26-2012, 02:36 PM   #24
Missouri Bound's Avatar
Gable Fan Switch
You can tell that by looking at it?
The only way to determine what it is really for is to see how it's wired.
Depending on the amount of terminals on the switch it could be an override switch or a disconnect for the fan: and the pilot light could indicate when the switch is on, or when the fan is on.
Do you want it your way or the right way?
Old 09-26-2012, 02:49 PM   #25
ffemt121's Avatar
Gable Fan Switch
No I could tell by looking at it that it should have been in a box...I could also tell by looking at it that the wire should have been installed in a wall...just little things I've picked up!!! Hahahahahah
Oh, duh, you weren't talking to me. He is right though, it is a cut out switch...doesn't matter much now though, I replaced the switch entirely
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
