Old 09-22-2012, 01:36 PM   #1
ffemt121's Avatar
Gable Fan Switch
I'm trying to find out what I can about this switch,
It's 75w-125v for my gable vent fan. The previous owners did this "amazing" install job, but I'm wondering if it wouldn't be better to be on a thermostat controlled switch in the attic. Is the bottom part of this switch a thermostat or something else?
ffemt121 is offline   Reply With Quote
Old 09-22-2012, 09:56 PM   #2
Gable Fan Switch
Why not install a ridge vent and vent the whole attic instead of just one end, and never have to work on, or pay to run a fan agin?
Old 09-22-2012, 10:22 PM   #3
ffemt121's Avatar
Gable Fan Switch
Because I'm doing the best I can with the financial resources I have. The roof is 25 years old, but I need to squeak another year or two out of it. I don't have the $10,000+ for a new roof.
Old 09-22-2012, 10:37 PM   #4
Missouri Bound's Avatar
Gable Fan Switch
The bottom part of the switch almost looks like an indicator light. A thermostat will serve you better but if you install proper vents in the new roof "when you get one" the gable fan won't be used anymore. Whatever you decide to do wire it safely.
Do you want it your way or the right way?
Old 09-22-2012, 10:40 PM   #5
ffemt121's Avatar
Gable Fan Switch
Should I not waste the money on putting a thermostat up there before I replace the roof then?
Old 09-22-2012, 10:42 PM   #6
Gable Fan Switch
Well that's up to you. If you don't care about an automated device and you want to switch it manually.............it's your call. Just make whatever wiring that is there safe.
Old 09-22-2012, 10:58 PM   #7
ffemt121's Avatar
Gable Fan Switch
Nothing safe about the wiring in this house...I have yet to get in the attic and look, but the switch and wire was just punched thru the Sheetrock and hanging in a closet in the master bedroom
Old 09-25-2012, 04:21 AM   #8
new guy
Gable Fan Switch
That's quite the "amazing install". I'd need better photos to guess at what was hanging through the wallboard. You'll want to determine if the fan already has a thermostat in series with it, its setpoints, if there is overlimit protection (firestat), and if there is a manual cutoff switch.
Brian
bclee is offline   Reply With Quote
Old 09-25-2012, 06:19 AM   #9
ffemt121's Avatar
Gable Fan Switch
If I can get up in the attic today, I will see what else I can find up there..I'm guessing I will find an ID plate on this fan motor circa late 70's-early 80's...the access hatch to get up there will become a set of attic stairs at some point, but right now it's a 14" x 14" scuttle
Old 09-25-2012, 07:38 AM   #10
ffemt121's Avatar
Gable Fan Switch
Brian, just out of curiosity, where would I find that sort of equipment? Would it be attached to the fan's framework?
Old 09-25-2012, 10:19 AM   #11
ffemt121's Avatar
Gable Fan Switch
Here's how it looks in the attic..shouldn't these Wires be in conduit or that metal stuff incase squirrels get in?
Gable Fan Switch-image-2991527327.jpg   Gable Fan Switch-image-4204470081.jpg   Gable Fan Switch-image-4273603249.jpg   Gable Fan Switch-image-1574513709.jpg   Gable Fan Switch-image-962603697.jpg
Old 09-25-2012, 04:27 PM   #12
Gable Fan Switch
The thermostat is below the fan (that silver box with the screw to adjust on/off temp).
Metal cable should be attached to the JB with an approved connector, not hanging like that.
Nonmetallic cable (black stuff) should be stapled within ~ 8" of box and then like every 2'. I doubt squirrels will chew your cable; if they get in, you'll have other worries.
bob22 is offline   Reply With Quote
Old 09-25-2012, 04:42 PM   #13
ffemt121's Avatar
Gable Fan Switch
Great, thanks Bob. I will take the staples and hammer next time I go up there. How about that round junction box? Us it ok where it is or should I try to secure it to a joist.
Old 09-25-2012, 04:59 PM   #14
Gable Fan Switch
I'm no pro but I'm sure the local code wants them attached to a structural element (like the nearby beam or if wire length is an issue, you could add in a board sistered to nearby framing to secure it).
Old 09-25-2012, 06:37 PM   #15
kevinp22's Avatar
Gable Fan Switch
that round junction box needs to be secured to something (ie joists)
The JB that the conduit "almost enters" has a termostat control on it. whether it works or not is another question. The thermostat can be turned with a standard screwdriver
Personally I would not use this fan given its age and the many code violations involved in the install. If I did use it, I would want to manually turn it on and off and not run it while people are sleeping
kevinp22 is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
