G.E. Panel Neutral Lug Question. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 08:48 AM   #1
G.E. panel neutral lug question.
We need to tie the neutral bar in my G.E. main panel with the neutral bar in my generators transfer switch panel. The wire is a #6 gauge copper. There is no room to land this wire in my main panel. I have seen neutral lug kits for SQD panels at the box store that has two stab connectors on it so it can connect to the neutral bar where the individual neutral wires attach. I found an identical item (GE part TGL20) for use in a G.E. panel, but it is listed as a ground lug. It will accept the #6 wire that needs to be landed in the main panel and wonder if there will be an issue using this. I've included a photo.
exhdo1 is offline   Reply With Quote
Old 12-07-2011, 08:50 AM   #2
This is the photo
Old 12-07-2011, 09:11 AM   #3
Licensed electrician
Rewards Points: 1,766
Most neutral bars will accept up to a #4. The adapter you have can be used either for a neutral or a grounding conductor, depending on the bar it is installed in.
Old 12-07-2011, 09:33 AM   #4
Thanks for the reply Jim.
Service move - old panel, separating neutral and ground WillK Electrical 3 06-17-2011 08:18 AM
general service panel question about ground / neutral BlueBSH Electrical 3 03-17-2010 06:55 PM
GFCI feeing subpanel question scott2332 Electrical 45 02-28-2009 03:15 PM
Panel History (old Breaker Panel Question) jamiedolan Electrical 3 01-17-2009 03:27 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
