FWIW, Troubleshooting A Setup With Two 3-way Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 05-07-2009, 08:58 AM   #1
FWIW, troubleshooting a setup with two 3-way switches
Assign each switch a number.
With switch #1 & switch #2 down, light is on or off?
With #1 up & #2 down, light is on or off?
With #1 down and #2 up, light is on or off?
With #1 & #2 up, light is on or off?
In principle, with the answers filled in, the problem(s) can be pinpointed.
Test cases welcome. . .
Old 05-07-2009, 12:12 PM   #2
If the light isn't OFF with both switches down (or both up), I flip one of them over, or trade the two wires on the output screws. Problem solved. Because I like consistency like that. :D
thegonagle is offline   Reply With Quote
Old 05-07-2009, 01:59 PM   #3
Newbie Bill
Rewards Points: 522
Is it as easy as that? Cause I have a couple of 3 ways like that.
drtbk4ever is online now   Reply With Quote
Old 05-07-2009, 02:06 PM   #4
Rewards Points: 2,350
I like the lights to be off no matter what state the switches are in. So I just don't even hook the wires up to the switch.
Old 05-07-2009, 02:13 PM   #5
And for that they pay you the big bucks?
I'm in the wrong business!
Well. . .it is pretty safe that way. . .
Old 05-07-2009, 03:09 PM   #6
Well, yes. If there's enough slack in the wires and room in the box, why not just physically flip it over? And if there's not enough slack to do that comfortably, trade the two wires that are NOT the common connection (trade the two same-colored screws; leave the odd-colored one alone).
I like the lights to be off if they're both down because there's less confusion as to whether the socket is live when changing a light bulb. And there's less to think about if walking around to turn out all the lights; all the lights are off if every switch is down. But that's me. I don't think there's a rule, and I doubt most people care one little bit.
Old 05-07-2009, 03:25 PM   #7
But... umm... The lights will be off when both switches are up as well. Trying to arrange 3-ways by up/down position is pretty pointless.
Old 05-07-2009, 03:27 PM   #8
I'm also running a special on receptacles. I'll install a non-working receptacle anywhere for $299.95, plus parts. $176.88 each if you want 10 or more.
Old 05-07-2009, 03:39 PM   #9
True. (And if one's up and the other's down, it will be on.) You say it's pointless, but I already admitted that I doubt most people care. I'll count you as one among "most."
I'm not an electrician, but if I was and was on a job, I probably wouldn't worry much about it. But in my home (and at my dad's, where I've spent hours upon hours working to modernize his 1960 electrical system), I like it the way I like it. But I am a perfectionist.
Old 05-07-2009, 03:42 PM   #10
Newbie Bill
Rewards Points: 522
I care. You mean most people don't.
I have two 3way circuits where the lights are off when one switch is up and the other is down. That drives me NUTS.
I must be a little obsessive compulsive as I always ensure that both switches are in the DOWN position when the lights are off on the two 3way circuits that are installed correctly.
I was actually embarrassed to ask how to fix them.. Now I know.
Thanks guys.
Old 05-07-2009, 04:45 PM   #11
I'm not sure how perfectionism comes into play. I mean, if you have a wiring preference, then it is moot. I mean, I always put my travelers on every switch in the same order, the red traveler on the left terminal if you are facing the switch. This way, all switches in the same box will be in the same state, when they are up or down. But saying that the lights are off when the switches are down, is meaningless, because they are off when both switches are up as well.
If you are at a switch, and to turn the light off you have to push the switch up, do instead run to the other switch and push it down, so they'll both be down? Kinda defeats the purpose of having a 3-way.
Old 05-07-2009, 07:46 PM   #12
That's harder to fix than a 3-way
http://counseling4christians.com/Inc...fectionist.htm
Old 05-07-2009, 07:52 PM   #13
Newbie Bill
Rewards Points: 522
umm yeah, but only when I am leaving the house. Isn't it bad luck to have the lights off with the switches in the up position?
Old 05-07-2009, 08:02 PM   #14
electrician
I have found that most "perfectionists" are just bored people with way to much time on their hands. I tend to look at things the way my old building trades teacher taught me, he always said "We aint building a piano here boys".
There are much more important, much more interesting or much more fun things to do with your time than worry about 3 ways being up or down.
Silk is offline   Reply With Quote
Old 05-07-2009, 08:18 PM   #15
Try and tell THAT to a customer....
spark plug is offline   Reply With Quote
4 way switch troubleshooting DOITRIGHTTHEFIRSTTIME Electrical 25 05-07-2009 10:36 AM
Switches - Just Checking fuzzmartin Electrical 7 10-06-2008 01:48 PM
50+ year old home-all light switches one-way? mudpaw Electrical 13 06-22-2008 01:57 PM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 11:16 AM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
