Fuses To Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2010, 01:52 PM   #1
Question
fuses to breakers
hi my apt in nyc is prewar uses fuses and i want to convert to circuit breakers. a total re-wire is not feasible, any suggestions?
smithgrind is offline   Reply With Quote
Old 09-02-2010, 02:47 PM   #2
Just call me Andrew
Rewards Points: 1,020
Do you own this apartment?
Andrew
secutanudu is offline   Reply With Quote
Old 09-02-2010, 03:40 PM   #3
Licensed electrician
Rewards Points: 1,228
Unless you own the apartment it would be up to your landlord.
You would just change out the fuse panel and install a breaker box. Upgrading the grounding and bonding would probably also need to happen. A total rewire would not be needed.
Changing to breakers will not do anything for overloaded circuits or provide you with the ability to install 3 prong receptacles.
Tags
apartment , breakers , elctrical , fuses
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 08:07 AM
Can I install tandem breakers to stop my breakers from tripping? sofakng Electrical 1 04-29-2009 02:44 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 01:58 PM
fuses to breakers handyman1355 Electrical 17 10-19-2007 07:06 AM
fuses to circuit breakers!! help!! ilovemyfamily Electrical 5 07-24-2007 08:01 PM
