-   -   fuses to breakers (http://www.diychatroom.com/f18/fuses-breakers-80369/)
smithgrind 09-02-2010 12:52 PM
fuses to breakers
hi my apt in nyc is prewar uses fuses and i want to convert to circuit breakers. a total re-wire is not feasible, any suggestions?
secutanudu 09-02-2010 01:47 PM
Do you own this apartment?
Jim Port 09-02-2010 02:40 PM
Unless you own the apartment it would be up to your landlord.
You would just change out the fuse panel and install a breaker box. Upgrading the grounding and bonding would probably also need to happen. A total rewire would not be needed.
Changing to breakers will not do anything for overloaded circuits or provide you with the ability to install 3 prong receptacles.
