Fuse Question Expert Needed!! - Electrical - DIY Chatroom Home Improvement Forum
Old 08-23-2010, 10:26 PM   #1
Hello Everyone,
I was putting a new hood in tonight for above our stove. Me being foolish I didn't pull the fuse out and must have gotten a cut in one of the wires. Long story short I had sparks flying and blew the fuse. Keep in mind this is not a circuit breaker our house is so old it still has a fuse box. I replaced the fuse but certain things are not working and others are. The dishwasher works but the outlet the fridge is plugged into and the hood both do not work. Does anyone know what might possibly be wrong and how I could fix this?
Revs2Nine is offline   Reply With Quote
Old 08-23-2010, 11:33 PM   #2
Electrical Contractor
kbsparky's Avatar
Check your main fuses. You may have blown one of them as well.
-KB
Old 08-24-2010, 04:34 AM   #3
Rewards Points: 1,192
Replace bad fuse,then check for other damage. Sorry! check for other damage and then change fuse,
bobelectric is offline   Reply With Quote
Old 08-24-2010, 07:28 AM   #4
Rewards Points: 855
not an expert but...
after fuses are checked
the short circuit caused a high amount of current on the wire path back to the fuse panel. any weak link in that path would have been stressed until the fuse blew, especially if the fuse was a slow blow variety. any junction in that path was subject to failure, and should be evaluated. the receptacles not working may have a faulty connection inside on the hot or neutral wires. if you are not comfortable or competent doing the evaluation get help.
TimPa is online now   Reply With Quote
Removing 7301/301's from Amalgamated Electric fuse box. tdeg807 Electrical 5 10-27-2012 05:35 PM
HVAC fuse ejconcepcion Electrical 7 01-17-2010 03:46 PM
serial or parallel? hohadcr Electrical 6 11-21-2009 10:28 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
fuse went BANG davej Electrical 1 01-23-2006 12:37 PM
