Old 11-15-2011, 11:52 PM   #1
Fuse panel main breaker question
I am replacing an old screw fuse panel with a breaker panel. I have a new 200 amp panel but my wiring from the street is only good for 125 amps. Can I replace the main 200 breaker with a 125?
cjm94 is offline   Reply With Quote
Old 11-16-2011, 07:21 AM   #2
Licensed electrician
I have never seen a panel with a 125 main. Also the cost to buy and change it out would be more than the cost of a panel with a 100 or 150 already installed.
If you need the 200, the wiring needs to be brought up also. If you just need breaker space there are 100 amp panels with 30 spaces or a subpanel would help.
Old 11-16-2011, 07:24 AM   #3
Why do you say the wiring from the street is only 125A??? Most POCO lines are good for 400A, you then install a service entrance cable sized for your panel. For 200A you need 2/0AWG in copper , or 4/0AWGl in aluminum, that could vary depending on local code.
Old 11-16-2011, 07:38 AM   #4
The wiring to the outside meter is 2/0 aluminum and I looked at an online rating app and I thought it said goods to 125. I will just get a new panel they aren't that expensive. I just had a new 200 available for free thought I would see if it would work.
Old 11-16-2011, 08:43 AM   #5
joed's Avatar
You can replace the breaker. Check the price of the breaker compared to the price of new panel to decide which to buy.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-16-2011, 10:16 AM   #6
Limited Experience
Federal Pacific apparently made them in 1961. I have one of them. Which I want to toss soon.
raleighthings is offline   Reply With Quote
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 07:27 PM
Wanting to add a circuit breaker subpanel to fuse panel. humberguy Electrical 6 06-24-2011 11:18 PM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 09:00 PM
Distance between the main breaker panel and a manual transfer switch panel jerryallie Electrical 2 09-01-2010 09:11 PM
main breaker panel terminology question! jeffjohnson1 Electrical 3 09-30-2008 09:04 AM
