-   -   Fuse panel main breaker question (http://www.diychatroom.com/f18/fuse-panel-main-breaker-question-123606/)
cjm94 11-15-2011 10:52 PM
I am replacing an old screw fuse panel with a breaker panel. I have a new 200 amp panel but my wiring from the street is only good for 125 amps. Can I replace the main 200 breaker with a 125?
Jim Port 11-16-2011 06:21 AM
I have never seen a panel with a 125 main. Also the cost to buy and change it out would be more than the cost of a panel with a 100 or 150 already installed.
If you need the 200, the wiring needs to be brought up also. If you just need breaker space there are 100 amp panels with 30 spaces or a subpanel would help.
Just Bill 11-16-2011 06:24 AM
Why do you say the wiring from the street is only 125A??? Most POCO lines are good for 400A, you then install a service entrance cable sized for your panel. For 200A you need 2/0AWG in copper , or 4/0AWGl in aluminum, that could vary depending on local code.
cjm94 11-16-2011 06:38 AM
The wiring to the outside meter is 2/0 aluminum and I looked at an online rating app and I thought it said goods to 125. I will just get a new panel they aren't that expensive. I just had a new 200 available for free thought I would see if it would work.
joed 11-16-2011 07:43 AM
You can replace the breaker. Check the price of the breaker compared to the price of new panel to decide which to buy.
raleighthings 11-16-2011 09:16 AM
Federal Pacific apparently made them in 1961. I have one of them. Which I want to toss soon.
