Fuse Panel Grounding - Electrical - DIY Chatroom Home Improvement Forum
Old 07-05-2012, 12:31 PM   #1
Fuse panel grounding
Good day,
Thank you for taking the time to answer my questions. I have purchased a summer home and starting new with the electrical. I reside in Ontario and have pulled all permits and disconnected from the main line. I have 200amp service and installed a new fuse panel. With regards to grounding I require #6 Bare copper with a clamp to either a 3 foot grounding rod or grounding plate. If I go with the grounding plate how far down does it need to be and how far away from the residential building must it be? If I go with the grounding rod can I just use one 3 foot and how far away does it need to be from the residential building? The #6 bare copper wire then needs to be directly connented to the ground of the fuse panel plate/bus.
Secondly, I plan to have the microwave over the stove. Can the microwave and the overhead range light/fan be plugged into the same electrical outlet? On it's own circuit?
Thank you,
J
Cottage9 is offline   Reply With Quote
Tags
grounding
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 06:27 PM
More than just a ? on grounding size for sub panel. 52Caddy Electrical 1 05-27-2010 10:05 PM
Sub panel wiring & grounding kwcamaro Electrical 1 03-06-2010 08:58 AM
electrical fuse panel Snell Lancaster Electrical 4 01-10-2010 12:20 PM
sub panel grounding jprince Electrical 2 05-04-2009 07:15 PM
