Old 12-08-2009, 10:51 PM   #1
Question
Fuse box/Circuit breaker
I just bought a house about a month ago that's been "gutted" so I have alot of work to put in. Most of the work I've done before, but who ever decided to take from the house took the fuse box/circuit breaker box out. Now I don't know which one the house originally had in, or if it makes a difference. What I need to know is how do I figure out which wire goes where?
Mr.Phillips is offline   Reply With Quote
Old 12-09-2009, 07:13 AM   #2
Is the cable from the meter still there?? The size of that will determine the size of the service panel you can install, or install a new service drop sized for the panel you want to install. As for the wires hanging out. #14 go to 15A breakers, #12 to 20A breakers, etc., one wire per breaker. Don't forget to have all that inspected.
Old 12-09-2009, 08:18 AM   #3
Xtreme DIY'r
Contact the Power Company, they might be able to tell you the prior service - 100a...200a
Doesn't matter what wasa there before fuse/breaker
What you want now is a breaker box, fuses boxes are rarely installed now
If it is a decent sized house I'd go with a 200a service
Has the meter been pulled...whole house is dead ?
Tags
circuit breakers, electical wiring, fuse box
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 05:31 PM
A FUSE and BREAKER BOX COMBO? Pioneer Electrical 3 09-29-2009 12:05 AM
Replacing and Moving a Fuse box with a breaker box nightrook Electrical 18 09-24-2009 08:49 PM
Fuse / Breaker Mix Beren Electrical 2 05-26-2007 07:49 PM
HELP!!! Info on changing old fuse box to circuit breaker box BryanR Electrical 2 03-12-2006 05:26 PM
