Old 10-24-2013, 09:05 AM   #1
Share |
Fuse blocks needed
I am looking for 2 fuse blocks for an Arrow-Hart & Hegeman fuse box. I can use a CP-15 or CPS-15 fuse block.
I have a large circuit that goes everywhere and would like to divide it. I have space in the box for two more fuse blocks if I can find them. And before you all get uptight, I am using a licensed electrician. We are working towards upgrading to circuit breakers, but the electrician would like to not do it "hot" and the electric company will require the entrance to be upgraded when the box is changed out. Too expensive at this time. So, if anyone has any of these blocks hanging around, I'd greatly appreciate it.
MaineLL is offline   Reply With Quote
Old 10-24-2013, 09:44 AM   #2
Licensed Electrician
k_buz's Avatar
Fuse blocks needed
Purchase a small modern sub panel for the temp use. Your electrician may even have an old one laying around.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
Philly Master (10-24-2013), plummen (10-24-2013)
Old 10-24-2013, 11:16 AM   #3
Fuse blocks needed
Parts such as you described are not available new, you might find a few old guys that keep that stuff, but I am sure you have tried google. Typically when what you are trying to do and parts are onsolete it is time for a panel change.
Know A Little is online now   Reply With Quote
Old 10-24-2013, 01:57 PM   #4
Master Electrician
Fuse blocks needed
Try The Light House Electrical Supply. (219) 362-8595. Ask for Dawn.
brric is online now   Reply With Quote
100AMP Main board off a 100AMP Main Fuse cmarcus3031 Electrical 18 03-19-2014 10:17 PM
FA4BNF024 HVAC Unit - Blows 5 amp low voltage fuse intermitently ArmyChief HVAC 33 01-28-2012 01:22 PM
Old Square D Fuse panel problem beadenuser7 Electrical 13 11-22-2010 01:30 PM
Fuse Question Expert Needed!! Revs2Nine Electrical 3 08-24-2010 07:28 AM
Problems with new fuse box for a dryer. needsomehelp Electrical 12 04-10-2008 11:20 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
