Furnace Won't Turn On When Reached Set Temp. Except When Wshich Is Turnedon Manualy - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 10:09 AM   #1
Furnace won't turn on when reached set temp. except when wshich is turnedon manualy
My furnace "forgets" to start when house temp. drops bellow the thermostat settings. I go in the basement and turn off the switch and then back on again and it starts working again. It started about 1 month ago and it only happened about 6 times with the exception of the last 2 days when we constantly have to manually turn off and back on the switch. It works fine until the temp. reaches the thermostats settings, and then again it won't start when temp. drops, except manually. Please help. I'm constantly running in the basement when it gets cold to manually turn on switch. If it's something I can fix myself I sure could save some $. Thank you!
John
stanulet is offline   Reply With Quote
Old 03-02-2012, 10:36 AM   #2
Rewards Points: 204
Sounds like the thermostat, thermostat wiring or fan relay. If you are not familiar with checking each one of these items, call an HVAC guy to come out. If you are familiar with checking these items, I am certain you will find your problem easily. Just keep in mind. The thermostat tells the furnace when to come on and when to go off.
Old 03-02-2012, 10:41 AM   #3
Rewards Points: 3,256
You might want to run this one by the folks in the HVAC forum.
The type of heat system and thermostat (manual/electronic) would be helpful also.
zappa is offline   Reply With Quote
Old 03-02-2012, 10:57 AM   #4
Furnace is a Bryant installed in year 2000, builders grade. Thermostat is an electrical/digital Honeywell.
Old 03-02-2012, 12:07 PM   #5
joed's Avatar
Rewards Points: 13,328
Sounds like a fault is occurring and the power off/on is resetting it. Is there any blinking lights? look in the manual for the code that will tell you what is the problem.
furnace blower won't turn on at night. mariamav3 HVAC 9 02-16-2012 07:54 PM
My temp sensor works, But the furnace not blow the heat, no heat may18 HVAC 3 01-06-2012 08:57 PM
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 03:22 PM
Help Please, Furnace won't turn on lh0628 HVAC 8 10-09-2007 03:07 PM
no heat when turn furnace on atl HVAC 1 10-24-2006 12:38 PM
