Furnace Won't Come On Unless.. - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2013, 12:56 PM   #1
Furnace won't come on unless..
Help!!This is my first visit to the chatroom. I have an old electric furnace and a wire to a little round looking relay melted off? The blower goes off also unless I tap this little relay. It comes on about 15 secs after I tap it. How do I find a new one? Is this a time delay relay?
ttoothache@wcc. is offline   Reply With Quote
Old 01-08-2013, 01:46 PM   #2
joed's Avatar
Rewards Points: 13,338
Start with the make and model of the furnace. Then go the furnace manufacturer site.
Old 01-08-2013, 07:30 PM   #3
Engineer
Rewards Points: 161
Not a time delay relay, just a defective one. It's an old trick to "tap" on a relay to get it to open/close, but yours is toast.
diystephen is offline   Reply With Quote
Old 01-09-2013, 11:17 AM   #4
Rewards Points: 204
Replace the relay unless you know how to check and see if indeed the relay is being called upon to operate? Meaning, is the relay coil receiving power to energize it. If it is receiving power to the relay coil and it does not operate, it is the relay.
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
