Furnace Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 05:12 PM   #1
Furnace wiring
The line to my furnace motor (natural gas) was a mess (from previous owners) so I ran a new line to it.
I ran 14/2 romex straight from the panel (15A breaker) to an emergency shut-off beside the furnance.
What wiring is required from the switch to the furnance motor? Can I run 14/2 romex, or does it need to be some sort of metal conduit?
Thanks!
zubor is offline   Reply With Quote
Old 08-26-2012, 05:37 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thanks!
You can use any chapter 3 wiring method... they are all acceptable.
Old 08-26-2012, 10:20 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Stickboy .,
While we are on OP's topic I am not too sure if the OP located but I did recalled that there are few states that will required addtional " remote " gas/oil furance shut off switch on stairway to basement or near the scuttle door for crawl space.
If your state do required can you post something related to your state?
To OP please tell us what state you are located this question may help you little more on this one.
Merci,
Marc
Old 08-26-2012, 10:21 PM   #4
E2 Electrician
Originally Posted by frenchelectrican View Post
Stickboy .,
Merci,
Marc
That would only be required by an oil fired appliance... local amendments may vary... but generally not required, just a local disconnect
The Following User Says Thank You to stickboy1375 For This Useful Post:
frenchelectrican (08-26-2012)
Old 08-26-2012, 10:22 PM   #5
Instering but thanks for giving me the answer.
Merci,
Marc
Old 08-26-2012, 10:23 PM   #6
E2 Electrician
Merci,
Marc
Oil makes a lot of smoke, hence the reason for the disconnect.
Old 08-26-2012, 10:27 PM   #7
Yeah that make sense but GPL ( Propane ) is about the worst due the GPL sink to the lowest spot one spark then Au revoir la maison ( Bye to the house ) I did survive GPL expolisoin twice.
Merci,
Marc
Old 08-26-2012, 10:29 PM   #8
E2 Electrician
Merci,
Marc
Its probably too late at that point. the smoke on the other hand, who wants to enter a space with smoke from floor to ceiling?
Old 08-26-2012, 10:31 PM   #9
Ouias ( Yeah ) I know what you mean with that. it the same idea in the garage when someone try to crank up coldblooded diesel engine the result is the same.
Merci,
Marc
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace Blower Wiring aboekman HVAC 4 07-18-2012 04:01 AM
Installing a Honeywell RTH2300B thermostat to a gas furnace. Have the standard WYRG wiring. Devan813 Electrical 3 12-25-2011 05:19 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 03:45 PM
