Furnace Powered By Generator - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-23-2012, 01:45 PM   #16
Rewards Points: 1,418
Install that Reliance single circuit transfer switch anywhere in the furnace branch circuit between the panel and the furnace. Or you can make your own using a (two gang size) junction box containing one three way switch and one 15 amp 120 volt male receptacle (inlet). An ordinary extension cord is plugged onto the inlet when generator power is needed.
The dark, or common, terminal of the 3 way switch is connected to the load, here, the line going down to the furnace.
Provided that the emergency switch's box has enough room in it, you could tie the lead from the transfer switch box in there.
The Following User Says Thank You to AllanJ For This Useful Post:
ralphfr (11-23-2012)
Old 11-23-2012, 01:54 PM   #17
Thumbs up
Since I already have the switch I will use it. Thank you for confirming this as a viable location. I appreciate it.
ralphfr is offline   Reply With Quote
Wiring generator to a dedicated panel? Djohnson6070 Electrical 5 11-11-2011 11:35 PM
HVAC system heat won't run with standby generator running... PTighe Electrical 70 09-14-2009 06:35 PM
240v Welder powered by portable generator? MRJChannahon Electrical 19 03-30-2009 06:19 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
240v Welder powered by portable generator jackgerd Electrical 10 11-06-2008 02:38 PM
