Furnace Power Drop - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2009, 03:23 PM   #1
Furnace power drop
How would I go about doing this? I assume I would install a junction at the joists and drop flexible metallic conduit to the furnace. I would ground the box and at the furnace. Wouldn't I need to secure the flex conduit to something if the drop is about 6ft?
rgsgww is offline   Reply With Quote
Old 01-26-2009, 03:25 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
A strap on the unit should be sufficient, just not on an access door.
wirenut1110 is offline   Reply With Quote
Old 01-26-2009, 03:50 PM   #3
Electrician
SD515's Avatar
Rewards Points: 504
I usually attach to the plenum with a clamp as it drops past it, and just above the handy box itself.
Kyle
Could I move my Meter & Power Drop to the Side of my house? jamiedolan Electrical 9 07-28-2010 05:16 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
