Furnace Ignitor - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 12:51 PM   #1
Furnace Ignitor
i have a carrier unit for my AC and HEATER. The control board model ins hkf42fz007. The ac will work fine but the heater does not seem to be working. The furnace will not ignite. The LED is a constant red on the board. The instruction informs that if it is constantly lit red, it has 24V. How do i make my furnace work? How do i make the furnace ignite?
farid is offline   Reply With Quote
Old 12-12-2010, 01:04 PM   #2
Master Electrician
Rewards Points: 3,810
Set the thermostat to 'HEAT' and set the temperature higher.
brric is offline   Reply With Quote
Old 12-12-2010, 01:08 PM   #3
thanx for the response. I have done that already.
Old 12-12-2010, 04:25 PM   #4
If you have a power vent remove the hose to the pressure switch and see if it is clogged.
hayewe farm is offline   Reply With Quote
Old 12-12-2010, 07:21 PM   #5
The circuit board has gone bad. I removed the power to the igniter connector and connected the multimeter and noticed that there was no power to this multimeter. The connectors responded fine to the multimeter. I guess i will have to replace the circuit board.
Thank you.
Old 12-12-2010, 10:28 PM   #6
" Euro " electrician
frenchelectrican's Avatar
You should post this part in HVAC section on this fourm one of the members will help you to make sure you are doing the right step before you get new circuit board.
There are few steps you have to follow to make sure to rule out any other safety issue like some safety switch kicked out that can prevent the furance get ingited.
Merci.
Marc
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Possible Lennox Furnace ignitor problem Paulg1 HVAC 4 11-26-2010 04:38 PM
Furnace Ignitor Was Clicking While Lit, Now Won't Light scribb HVAC 13 10-12-2009 01:00 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
