Furnace Fan Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2011, 05:10 PM   #1
Furnace fan motor
Why won't the furnace fan motor run with another electrical circuit in the house or from a home generator?
DENROB is offline   Reply With Quote
Old 11-19-2011, 05:33 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
A new problem since a new circuit was pulled? Does it not run in any call or just heating or in only cool? What's the voltage to the furnace?
And albeit this is an electrical problem you may want to post this down in the hvac section. All hvac techs are electricians by trade as well.
Variable speed furnace or single state? 240 volt or 120?
Doc Holliday is offline   Reply With Quote
Old 11-19-2011, 06:14 PM   #3
Code05's Avatar
Rewards Points: 1,104
What, you are not psychic? You expect actual info in order to answer?
Code05 is offline   Reply With Quote
Old 11-19-2011, 09:24 PM   #4
No kidding. All you can do is try..
Old 11-19-2011, 09:26 PM   #5
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Assuming the motor is in working order, it could be there is no power going to it. This could be due to an external cause.
Red Squirrel is online now   Reply With Quote
Old 11-19-2011, 11:35 PM   #6
Idiot Emeritus
Rewards Points: 1,492
Generally speaking, the more electronic the controls are, the better the power needs to be. Most small generators produce lousy power, and won't run electronic controls.
Rob
micromind is offline   Reply With Quote
Old 11-20-2011, 11:06 AM   #7
joed's Avatar
Rewards Points: 13,710
It should run if it is getting power. The problem could be the low voltage transformer for the thermostat is on a circuit that is not on the generator.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace Blower Motor bdoehring HVAC 11 06-13-2011 08:58 PM
furnace blower motor 590610jt HVAC 1 05-22-2011 11:02 AM
ICP Furnace Blower Motor SheeB HVAC 8 04-17-2011 12:42 PM
Carrier Furnace Vent Motor Question ajay12 HVAC 1 12-23-2008 10:23 PM
