Furnace Fan Control - Electrical - DIY Chatroom Home Improvement Forum
Old 11-05-2011, 11:50 AM   #1
furnace fan control
having trouble wiring in new furnace control white rogers type 8a05a-101 fan centre instructions show internal wiring but not external
and i know two wires go together
Dirtydan is offline   Reply With Quote
Old 11-05-2011, 05:45 PM   #2
DIY staff
Rewards Points: 7,174
Dan---post a picture of the instructions--or give us something to go on.
If English is a second language for you do the best you can.
Old 11-05-2011, 08:53 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Main hot wire to furnace will need a pig tail to line 1 (possibly labeled line h on board) and one wire goes to the transformer. That's three main hot wires in one wire nut.
Other than that and on the low control voltage side, the cool terminal, labeled Y on the board, will have one wire to the condenser and one to the stat. Two wires there on one terminal.
Pics would help. Not only the diagram but the unit and board and all wires.
Doc Holliday is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace Control Board. JJboy HVAC 2 12-19-2010 12:42 PM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 03:27 AM
Universal furnace control board Davidj0717 HVAC 1 10-14-2009 05:37 PM
heil gas furnace fan control shooter49 HVAC 1 10-24-2008 01:51 PM
