Furnace Electrical Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2013, 12:57 PM   #1
listo's Avatar
Rewards Points: 95
Furnace electrical conduit
Up in Canada here, anyone know if I can use PVC conduit for the furnace wire? I'm I correct in thinking the thermostat wire doesn't need a conduit?
listo is offline   Reply With Quote
Old 08-10-2013, 02:05 PM   #2
A pro will come along soon...but this civilian has never seen 24V thermostat wire in conduit.
RoyalAcresRod is offline   Reply With Quote
The Following User Says Thank You to RoyalAcresRod For This Useful Post:
raylo32 (08-17-2013)
Old 08-10-2013, 02:19 PM   #3
listo's Avatar
Rewards Points: 95
But is pvc ok for the main power lines?
Old 08-10-2013, 02:45 PM   #4
I do not know CA codes on this. I've always used FMC for furnace electrical lines.
listo (08-10-2013)
Old 08-10-2013, 02:45 PM   #5
FMC: flexible metal conduit.
listo (08-10-2013)
Old 08-10-2013, 02:51 PM   #6
listo's Avatar
Rewards Points: 95
Fmc? What's that?
Old 08-11-2013, 09:40 AM   #7
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by listo
Fmc? What's that?
Greenfield.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-16-2013, 11:19 PM   #8
just use bx cable from switch to furnace
onorio56 is offline   Reply With Quote
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 03:13 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 12:33 PM
Electrical conduit support. kontoose Electrical 3 07-07-2012 05:32 PM
Electrical conduit coming through foundation leaking inside Madmike7221 Electrical 2 05-09-2012 08:52 AM
Rewiring furnace electrical circuit BlueBSH HVAC 4 09-21-2010 02:34 PM
