Old 11-06-2012, 03:34 PM   #1
furnace
the only way i can get voltage to the thermostat (2 wire b & w) is warm up the gas valve with a hair dryer. then the furnace works great.then after it shuts off there is no voltage to thermostat.then warm the valve up again. does this mean a new gas valve or is there something i can do to keep voltage to the thermostat.
jaspe is offline   Reply With Quote
Old 11-06-2012, 10:38 PM   #2
joed's Avatar
furnace
Sounds like possibly a milivolt system. There should be a thermocouple in the pilot that produces a few milivolts to run the valve and the stat.
Do not PM with questions that can be asked in a forum. I will not respond.
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
