Furance Pressure Switch Is Open - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2007, 04:09 AM   #1
Furance pressure switch is open
Hi,
I am having a problem with my Ruud Achiever 90 plus furance, after 41/2 years the pressure switch is open code 2 keeps happening. I've been told that it could be the wind direction, to many bends in the intake pipe, or to long of an intake pipe. but when the service people come out they have manually unstuck the pressure switch and then leave. I wonder why they don't replace it? They tell me that it is stuck because the above things. Is that true or should it be replaced? They have only charged me twice out of the 5 times, but now want to come out and do a bunch of testing. Can the problem be discovered if the code isn't flashing? Do I have to wait for the code to flash again for them to find the problem? For what possible reasons does it throw this code? Can anyone help?
Saber
Saber is offline   Reply With Quote
Old 03-13-2007, 05:46 PM   #2
Rewards Points: 150
if it's been working for 4 years, and you haven't modified anything, and it just stopped working, then chances are the switch is bad... i'm sure they'll change it if you pay them to...
elementx440 is offline   Reply With Quote
Old 03-13-2007, 10:02 PM   #3
scotch on the rocks
hvactech's Avatar
there was a recall on some of the pressure switches, you should ask your local rheen/ruud wholeseller about it.
hvactech is offline   Reply With Quote
Old 03-16-2007, 11:38 PM   #4
furnace pressure switch reply
Thanks for all your help I will take what has been said and use that information to get my furance fixed! Thank You!
Saber
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
RUUD Gas Furnace Pressure Switch? erik11 HVAC 8 12-07-2006 12:39 AM
PAYNE Pressure switch error code 23 WRKPA HVAC 1 02-04-2006 07:37 AM
What engages pressure switch? dfferg HVAC 1 09-12-2005 11:27 PM
