Old 10-30-2008, 04:28 PM   #1
Question
funky plug-in connectors in new recessed lights
the recessed lights i bought last year came with regular loose three wires that needed to be spliced and capped to wire in and out, if any, the old-fashioned way.
however, the same lights i just bought a few weeks ago came with some funky plug in contraptions that lock the wire pushed in and, to my understanding, there is no way out but cutting the wire. there are four holes in each connector.
Q1: what do you call that connector ?
Q2: any cons to this solution. looks like cheating to me. should i have done away without it, cut them out and splice the wire ?
Old 10-30-2008, 05:37 PM   #2
Electrical Contractor
They are called wago's or whatever brand that the light company uses. They have been there for several years and you can either cut them off or use them.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
Old 10-30-2008, 05:44 PM   #3
Licensed Pro
Use them. They are a great time saver when installing multiple lights and are a vast improvement over the old push-ins used on receptacles. To remove the 14/12ga wire, just pull while twisting the connector.
Old 10-30-2008, 05:57 PM   #4
Question
why not then use them universally in all applications instead of splicing wires, which is something i seldom look forward to doing, especially with 4 gauge 12 wires ?
Old 10-30-2008, 06:34 PM   #5
Licensed Pro
That's easy: $$$$$$$$$$$$$$.
But they do work well when you have several grounds or neutral to connect together.
Old 10-30-2008, 07:49 PM   #6
They rock!
Carpel tunnel is not good.
220/221 is offline   Reply With Quote
Old 10-30-2008, 07:52 PM   #7
Originally Posted by 220/221 View Post
They rock!
I agree. I put 32 recessed lights in my brother's house and they were a huge timesaver.
jerryh3 is offline   Reply With Quote
Old 10-30-2008, 08:42 PM   #8
nap
You talking to me?
nap's Avatar
I fell in love with these things for lighting installs. When you can have hundreds of lights in one install, the time savings can be considerable.
While they are rated for higher current ratings, I tend to relegate them to lighting installs, for now. Most of them are rated high enough to be used in place of wire nuts in most situations.
and as to cost; if you compare a name brand wire not to these, they are not that much different. The time savings make up for the costs from what I can see.
Old 10-30-2008, 10:06 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
I LOVE these things as well.
I also like the quick wire connectors where you can splice two cables to the light and slip them into the two black "clips" AFTER everything is wired up.
Airtight recessed lights sluggermike Electrical 23 03-22-2013 10:42 AM
Recessed lights in the same soffit as HVAC and PEX cygnl7 Electrical 5 05-16-2008 10:54 AM
Replacing hall light fixtures with recessed lights POMEXCAN Electrical 3 04-16-2008 11:40 PM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 01:39 PM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 06:02 PM
