Funky 3-way - Electrical - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 09:35 PM   #1
Rewards Points: 121
Funky 3-way
Hey All,
Let me know if this works. I have 14-2 (power feed) coming to a switch box (box #1). I then have a 14-3 (leaving box #1) going over to the other side of the room (not touching lights) to another switch box (box #2). I then have a 14-2 (light feed) coming to switch box #1.
If I land the 14-2 (power feed black) on the common on the 3-way in box#1. Land the 14-3 black/red as travelers to the 2nd 3-way switch over at box #2. Use the 14-3 white w/black tape on the common of the 3-way in box#2. In box #1 take returning white 14-3 (w/black tape) and splice to the black wire of 14-2 for the feed to the lights and then splice the remaining 2 whites (white from power feed and white from light feed).
Thanking you in advance.
icepal1999 is offline   Reply With Quote
Old 08-08-2011, 10:05 PM   #2
I=E/R
a7ecorsair's Avatar
Looks good but use the re-identified white as one traveler and red as the other.
a7ecorsair is offline   Reply With Quote
Old 08-08-2011, 10:05 PM   #3
Rewards Points: 1,418
You have the connections correct.
One tiny detail: The switched hot coming back to switch #1 box and connected to the light feed may not be the white wire.
The Following 2 Users Say Thank You to AllanJ For This Useful Post:
frenchelectrican (08-09-2011), SD515 (08-08-2011)
Funky smell in my wooded kitchen cabinets jmann General DIY Discussions 4 10-07-2010 02:09 AM
Funky old ITE panel McSteve Electrical 6 08-18-2010 07:34 PM
Funky wiring in Kitchen Atreyou40 Electrical 10 08-24-2009 11:05 AM
Need sugestions for funky painted stirps in 1/2 bath harleysilo Interior Decorating 2 01-28-2009 12:55 PM
funky plug-in connectors in new recessed lights amakarevic Electrical 8 10-30-2008 10:06 PM
