Full Switched Outlet To Full Hot. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-02-2012, 05:29 PM   #16
Originally Posted by Marc05 View Post
Ok. Go with the second part of my first post
I will try this and report back.
BerMik is offline   Reply With Quote
Old 11-02-2012, 05:59 PM   #17
Rewards Points: 2,516
Originally Posted by BerMik View Post
My best guess would be this,
One wire is from the switch.
One wire to the ceiling light.
One wire is power in.
One wire is power to the rest of the circuit.
For future reference: a wire is a wire and a cable is not a wire.
hammerlane is offline   Reply With Quote
Old 11-02-2012, 06:07 PM   #18
Cable "D" is One wire is from the switch.
Cable "B" is One wire to the ceiling light.
Cable "C" is One wire is power in.
Cable "A" is One wire is power to the rest of the circuit
In the diagram below, the receptacle will be always hot and the switch will control the light.
The Following User Says Thank You to hammerlane For This Useful Post:
BerMik (11-03-2012)
Old 11-03-2012, 05:37 PM   #19
Works like a charm, thank you guys.
Now I will fix the other two bedrooms that are the same way.
Cheers.
Twist lock switched outlet and timer for pool ggnuncleb Electrical 2 05-12-2012 03:44 PM
switched outlet Andretti Electrical 6 03-15-2012 05:18 PM
Switched outlet bryanp22 Electrical 1 11-02-2011 05:51 AM
Switched Outlet, Power into the switch then to switched receptacle ryanwake Electrical 1 01-23-2011 12:52 PM
rewire switched outlet for ceiling fan MAB Electrical 4 08-02-2009 06:37 PM
