Frontier TM-619 Digital Timer Connections - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-20-2010, 08:09 AM   #16
Question
Thankyou
a7ecorsair
When I got that reading I was worried that this was the explanation.
Is there any way I can still use this timer in this installation??
Can you suggest an alternative timer that WILL operate in this installation?
The solar flood light naturally turns on at dusk, however, I want to control that so it only operates the flood light for a set number of hours prior to dawn so as to increase the daylight hours in my remote poultry shed.
Any suggestions at all??
Cheers,
Neil
neildawes is offline   Reply With Quote
Old 07-20-2010, 08:27 AM   #17
I=E/R
a7ecorsair's Avatar
If you want to run this setup on solar you will need to power the timer separate from the flood. The flood would only use 3 and 5.
You will have to find a small 12V sealed lead acid battery and a 12V solar charger. This would be connected to 1 and 2.
Craig
a7ecorsair is offline   Reply With Quote
Old 07-20-2010, 08:34 AM   #18
Well that might well be possible.!!
Another option, would the LED flood light work on the same 12V or would the LEDs burn out. Not very familiar with this technology
I could then run the whole thing on an old 12V battery and just charge it up as required.
If it would work:
How much power would the whole thing draw, so as to
estimate battery life between charge ups.
Many thanks for your help and expertise.
Neil
Old 07-20-2010, 08:55 AM   #19
I=E/R
a7ecorsair's Avatar
Don't run the flood on 12V.
A car type battery would work but you would have to charge it once in awhile. If you had a high amp hour deep cycle battery it might run for a long time. I doubt that the timer requires much for current.
Old 07-20-2010, 05:33 PM   #20
Hi,
I'm not sure of your last reply.
Are you saying that I shouldn't put 12V through the LED flood light, due to it burning out perhaps or not?
As for power consumption of the 20+ LED's in the flood light, I thought that would be quite tiny and a car battery should last days??
Perhaps showing my ignorance of LED's here!( I think: LED draws approx 60mA and timer 5mA using a multimeter)
Regards,
Neil
Old 07-20-2010, 11:02 PM   #21
Smile
Hi,
I have now tested the timer in a 12V environment; 12V battery feed to the timer (connections 1. and 2. ) and a 12V feed into an automotive light globe (connections 3. and 5. )
IT WORKS !!!! YEAH !!!!
There is a distinct click when the MANUAL button changes the setting from OFF to ON
The timer switches the light on when in range.
So now I can run the timer as suggested on a 12V battery supply and let the solar panel just supply the LED flood lightís 6V battery.
Still havenít heard if an entirely 12V environment would be OK.
eg 12V to the Timer and 12V to the previously 6V, 20+ LED flood light. Would this harm the LED lights??
What current draw, hence charge life should I expect from an automotive battery (large one previously in my diesel 4x4) power supply before being necessary to mains charge it?
Your feed back would be much appreciated still.
Regards,
Neil
Old 07-21-2010, 08:49 AM   #22
Bumped
Old 07-22-2010, 06:05 AM   #23
Hi again,
I use my multimeter to measure the current drawn by the flood light to be 60mA and the timer at about 5mA.
Could the following set ups satisfy the two voltage requirements? 12V for the timer and 6V for the LED flood light.
Best wishes,
Neil
Old 07-22-2010, 12:05 PM   #24
I=E/R
a7ecorsair's Avatar
Hi,
I'm in the process of rebuilding my cabin so haven't had internet for a couple of days. I got the phone and DSL moved to the 5th wheel camper so I'm back on.
The first diagram looks best but how will you charge the one 6v battery?
The reason I said not to connect the flood to 12V is because it is designed to run on 6 V and you'd probably burn up the flood on 12 V.
What are you using for the one 6v battery?
Since the one battery will be driving the flood it may loose power faster than the other battery and then the timer would stop.
Why don't what to run the timer on its own 12V battery?
Old 07-22-2010, 05:25 PM   #25
Hi,
Now that I understand the electrical requirements I can go forward with this. The option I use will depend upon what batteries / panels etc I can put to gether.
VERY MANY thanks,
Neil
Old 10-19-2010, 02:33 PM   #26
TM 619 wiring
We supply as lot of these, so here's some help. 1 and 2 are for power to the timer ONLY. 3 is common, 4 is normally closed and 5 is normally open. Bring your 12 volts to 1 and 2 to power the timer. Take the hot lead from your battery into 3. take the same lead out of 5. Basically you are splicing the timer into the hot lead. That should do it! To check if it's working push the "manual" button.
Good luck
247roger is offline   Reply With Quote
Old 09-04-2013, 08:34 AM   #27
how to connect tm-619H timer
hi i have problem to connect my TM-619H digital timer to my 12V DC water pump.
i use 12V DC battery to powered my timer.
please help me
jy1764 is offline   Reply With Quote
Old 09-04-2013, 09:09 AM   #28
Master Electrician
Rewards Points: 3,746
please help me
This thread is two years old. Start a new thread.
brric is online now   Reply With Quote
GE Smart Digital Timer Trevis Electrical 21 09-08-2011 11:17 PM
Wiring GE Smart Digital Timer to 3 way switch. Wing Electrical 16 08-26-2010 07:22 PM
Wiring Bathroom Fan Timer - Connections Trick46 Electrical 6 06-25-2009 05:47 PM
Help with digital timer wiring longman Electrical 7 12-06-2008 12:22 PM
Digital timer problems bazzer Electrical 4 11-20-2006 06:44 AM
