Front Porch Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2008, 02:19 PM   #1
Question
Front Porch Lights
Hello fellows, how do you guys normally install a front porch light fixture receptacle? The inside is at rouch in stage. There is two different layers of boards on the outside with metal siding. I can't exactly just cut a big hole and mount the box.
It would be ideal to have an adustable box to mount to the 2x4, adjust it so its flush with the extra 2 inches of boards before the metal siding and then install a waterproof housing. I have no idea, so any insight on how to tackle this issue would be greatly appreciated.
matrix733 is offline   Reply With Quote
Old 03-16-2008, 02:30 PM   #2
Fixture or a recepticle?
Fixture = light, recep = outlet that you plug something into.
Are you plugging a fixture into the recep??
Well...you are goinf to have to cut/drill some kind of hole.....right?
220/221 is offline   Reply With Quote
Old 03-16-2008, 02:43 PM   #3
Electrician
Here is a list of all types of siding blocks...
http://www.aifittings.com/arliprod6.htm
chris75 is offline   Reply With Quote
Old 03-16-2008, 10:04 PM   #4
get a 4" hole saw at Lowes or HD for $30.00 and drill a hole from the outside where you want your light, then mount your box, then run your wires to it.
hammer is offline   Reply With Quote
Old 03-16-2008, 11:18 PM   #5
its for a fixture..
I know I have to drill a hole but the fixtures I see at HDepot & Lowes have the nails in an ackward position. I might be just looking in the wrong area.
Old 03-17-2008, 08:33 AM   #6
Licensed electrician
Rewards Points: 1,892
The mounting brackets will be adjustable on the fixture box so that the fixture will be oriented correctly.
PS, they are screws, not nails.
Installing new front porch columns puma24boy General DIY Discussions 2 12-03-2007 03:27 PM
stripping paint off my front porch pesphoto Remodeling 5 11-08-2007 06:56 AM
Porch lights with timer or photocell? ciera Electrical 4 10-29-2007 07:35 AM
Front porch wirenut Building & Construction 7 08-27-2007 05:44 AM
Repainting Columns on front porch R Parker Painting 10 04-17-2006 08:37 AM
