Fried Wires In Circuit Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 12-08-2012, 01:58 PM   #1
Fried wires in circuit breaker box
In my breaker box I noticed today that some wires are charred, black, and halfway missing (see picture). Anyone know what would cause this and what should I do to fix it? Can I cut the wires and replace them?
DIY_electric is offline   Reply With Quote
Old 12-08-2012, 02:02 PM   #2
Rewards Points: 78
You need to upload a picture of the panel. What you have sounds very dangerous. So wheres the picture?
Old 12-08-2012, 03:47 PM   #5
Rewards Points: 13,260
What's the brand name on that breaker?
Your very close to having a house fire.
Call a real electrition ASAP.
Old 12-08-2012, 03:49 PM   #6
General Electric
Old 12-08-2012, 04:18 PM   #7
TTW
TTW's Avatar
You need an electrician... NOW!
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-08-2012, 04:41 PM   #8
I've called a few and hopefully i can get someone out here today. should i just turn off the circuits going to those group of three wires or should i turn off all the power to the house?
Old 12-08-2012, 07:14 PM   #9
all fixed! he used a smaller wire so I hope it is up to code.
Old 12-08-2012, 07:17 PM   #10
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The fix for that problem was not to use smaller wires. What did he document as the cause of the problem?
The Following User Says Thank You to k_buz For This Useful Post:
Hardway (12-09-2012)
Old 12-08-2012, 07:27 PM   #11
TTW
TTW's Avatar
are you being facetious?
Old 12-08-2012, 07:28 PM   #12
he said that when they took the outer sheath off the wires they accidentally cut a small slit into the wires. Over time these opened up more and more.
He showed me where there were other cuts on the other wires going out of the box along the same "path" where the fried place was on the bad wires.
The Following User Says Thank You to DIY_electric For This Useful Post:
TTW (12-09-2012)
Old 12-08-2012, 07:32 PM   #13
k_buz's Avatar
THAT I can believe, but I am curious about using "smaller wire"...or does it just appear to be smaller wire?
Have any pics of the fix?
Old 12-08-2012, 07:57 PM   #14
The wire just appears to be smaller, it could be the same size with better coating making it thinner. The new wire is the fourth wire from the top in this picture.
http://24.media.tumblr.com/6f2027298...16y5o1_500.jpg
he ran a new wire from the breaker to the place where the wires were fried.
here is a picture of the fix: http://25.media.tumblr.com/b7ae28118...16y5o1_500.jpg
notice the wire caps. Seems like there would be a better solution to connect the wires other than the wire caps.
TTW (12-09-2012)
Old 12-08-2012, 08:07 PM   #15
k_buz's Avatar
Not the way I would have done it, and I could argue that it doesn't meet code, but that would be nit picking. Looks safer now.
Main Circuit Breaker Test lthomps222 Electrical 16 11-07-2010 05:40 PM
900W and up trips breaker, Circuit draws power even with everything off... jasonblu Electrical 40 12-09-2009 03:29 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 09:52 AM
Insulation around a electrical circuit breaker box terpsing Electrical 4 02-03-2009 04:08 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
