Old 09-10-2008, 10:12 AM   #1
Question
fridge on the same 20A circuit with microwave
i am tempted to do this simply because i am out of slots on my panel. i was told fridge should be on its own dedicated circuit, which i see the benefits of but it may not be doable for me. will i be okay ?
Old 09-10-2008, 10:35 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
What type of microwave? Fastened in place above the range or just a cord and plug model? Generally this is fine to include the fridge on a small appliance branch circuit with other loads. The problem occurs when the microwave is fastened in place and uses more than 10 amps. In which case the microwave would need to be on its own individual branch circuit.
Old 09-10-2008, 10:47 AM   #3
Fastened in place above the range.
Old 09-10-2008, 11:15 AM   #4
Licensed Pro
That will require a dedicated circuit. The refrigerator does not require one, and can be placed on one of the small appliance circuits. I would advise that if you do that though, to make sure it is NOT part of the GFCI protected circuit.
Old 09-10-2008, 12:22 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Most likely as Househelper said it requires an individual circuit. Are you sure your out of spaces in your panel? Some panels will accept tandem single pole breakers that give you two branch circuits in one space and some single pole breakers like square d Qo and homeline will allow two wires under one terminal. You wouldn't want the fridge and micro under the same breaker but it may allow you to free up a space to install an individual circuit for the micro.
Old 09-10-2008, 07:10 PM   #6
Put the micro on the dedicated circuit. The refer can go on one of the kitchen outlet circuits (line side of the GFCI is suggested)
220/221 is offline   Reply With Quote
Old 09-10-2008, 11:03 PM   #7
Electrician
Unless you live in Canada, then your fridge has to be on its own circuit.
darren is offline   Reply With Quote
Old 09-12-2008, 10:02 AM   #8
You say your out of spaces in your panel, can you use a piggyback breaker? Check out this site!
http://www.gordonelectricsupply.com/index.jsp?path=find
Woodyh1 is offline   Reply With Quote
Old 09-12-2008, 10:11 AM   #9
Woodyh1: What exactly are we supposed to see at your link, all it says is no item found.
daxinarian is offline   Reply With Quote
Old 09-12-2008, 08:03 PM   #10
Electrician
Untrue. Also, I would not loose any sleep putting a fridge on a gfci protected circuit.
chris75 is offline   Reply With Quote
Old 09-12-2008, 10:45 PM   #11
Electrician
This is very true, a fridge needs a dedicated circuit, the only other thing allowed on a fridge cicuit in Canada is a recessed clock plug.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 9 03-22-2011 09:40 PM
Need a wiring diagram Mooreski Electrical 46 03-12-2011 04:25 PM
split receptacle for fridge & microwave? Beren Electrical 26 08-24-2008 11:05 AM
Microwave trips GFCI on a different circuit! Frank Kolwicz General Discussion 7 06-01-2008 09:48 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
