-   -   fridge on the same 20A circuit with microwave (http://www.diychatroom.com/f18/fridge-same-20a-circuit-microwave-26593/)
amakarevic 09-10-2008 10:12 AM
i am tempted to do this simply because i am out of slots on my panel. i was told fridge should be on its own dedicated circuit, which i see the benefits of but it may not be doable for me. will i be okay ?
Stubbie 09-10-2008 10:35 AM
What type of microwave? Fastened in place above the range or just a cord and plug model? Generally this is fine to include the fridge on a small appliance branch circuit with other loads. The problem occurs when the microwave is fastened in place and uses more than 10 amps. In which case the microwave would need to be on its own individual branch circuit.
amakarevic 09-10-2008 10:47 AM
Fastened in place above the range. :(
HouseHelper 09-10-2008 11:15 AM
That will require a dedicated circuit. The refrigerator does not require one, and can be placed on one of the small appliance circuits. I would advise that if you do that though, to make sure it is NOT part of the GFCI protected circuit.
Stubbie 09-10-2008 12:22 PM
Most likely as Househelper said it requires an individual circuit. Are you sure your out of spaces in your panel? Some panels will accept tandem single pole breakers that give you two branch circuits in one space and some single pole breakers like square d Qo and homeline will allow two wires under one terminal. You wouldn't want the fridge and micro under the same breaker but it may allow you to free up a space to install an individual circuit for the micro.
220/221 09-10-2008 07:10 PM
Put the micro on the dedicated circuit. The refer can go on one of the kitchen outlet circuits (line side of the GFCI is suggested)
darren 09-10-2008 11:03 PM
Unless you live in Canada, then your fridge has to be on its own circuit.
Woodyh1 09-12-2008 10:02 AM
You say your out of spaces in your panel, can you use a piggyback breaker? Check out this site!
http://www.gordonelectricsupply.com/index.jsp?path=find
daxinarian 09-12-2008 10:11 AM
Woodyh1: What exactly are we supposed to see at your link, all it says is no item found.
chris75 09-12-2008 08:03 PM
Untrue. Also, I would not loose any sleep putting a fridge on a gfci protected circuit.
darren 09-12-2008 10:45 PM
This is very true, a fridge needs a dedicated circuit, the only other thing allowed on a fridge cicuit in Canada is a recessed clock plug.
