Fridge Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 10-01-2012, 10:03 PM   #1
fridge outlet
redoing kitchen- Fridge now going on other wall in kitchen.
Question 1: Does fridge outlet need to be located higher on wall then a standard outlet?
Question 2: It should be on it's on line directly back to the panel correct?
Right now (where the new fridge is going) there is a standard outlet in the wall ( like 14" off ground)- it's wired in with other outlets but since the cutout it there- do I just rewire the existing one running a dedicated line back to the box- or just install a new one higher on the wall?
skinut2234 is offline   Reply With Quote
Old 10-01-2012, 10:26 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Why does it have to be moved?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 10-01-2012, 11:04 PM   #3
wasn't sure if the outlet needs to be higher on the wall or not
Old 10-01-2012, 11:18 PM   #4
Licensed electrician
Rewards Points: 1,296
It doesn't have to be, but you may find it more convenient higher up,
Old 10-01-2012, 11:51 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I like it about counter top level. It is important to understand that remodling of a kitchen requires that it meets the current electrical code that your jurisdiction has adopted. This is a reasonably good link to those requriements ...
http://www.hopewelltwp.org/Single%20...quirements.pdf
How to add another electrical outlet in bedroom? AMG Electrical 33 09-15-2012 10:20 PM
dedicated outlet for undercounter fridge? BlueBSH Electrical 9 11-25-2011 01:24 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Bathroom GFCI Outlet trouble RyG1357 Electrical 3 08-20-2011 04:40 PM
