Fridge And Lights? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-29-2010, 07:00 AM   #1
Rewards Points: 204
Fridge and lights?
I am finishing my basement and have a question about my fridge circuit. I was wanting to run my fridge and 4 can lights off of a 20 amp circuit. I tried to see how much power the fridge draws but couldn't find it. Wattage wise I should be ok. 4x75w = 300W, so that leaves me with over 1600 watts to stay under 80%.
Does a fridge have to be on it's own separate circuit. My house was built in 2006 and the Kitchen fridge isn't on it's own, I just wanted to make sure before I start running wire.
Abs777 is offline   Reply With Quote
Old 04-29-2010, 07:24 AM   #2
Licensed electrician
Rewards Points: 1,752
To find your data plate for the refrigerator look on or near the door.
Unless called for by the installation instructions a separate circuit is not required.
Loadwise you will be fine. A typical refrigerator draws around 7 amps, but more while starting up. You may notice the lights dim when the refrigerator starts.
Old 04-29-2010, 08:06 AM   #3
Rewards Points: 204
Thanks. I looked in the manual and it says that a 15 or 20 amp circuit is required. It says "recommended" being on it's own circuit.
Old 04-29-2010, 09:23 AM   #4
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Mike Holmes said the same thing Sunday
Recommended, not required.
CoconutPete is offline   Reply With Quote
Old 04-29-2010, 10:07 AM   #5
I put my kitchen fridge on its own 15a circuit w/12g wire (had the breaker)
My old 18cu ft fridge was rated at 4.75a
The new 26 cu ft is supposed to use less power on a yearly basis
BUT, its rated at 11.6a...approx 408w free of the 15a circuit
So in my case I will not add anything to the circuit
If I had installed a 20a breaker I might have added the lights
But since it is using 77% of the 15a circuit I'll leave it
Just not worth it to trip the fridge
You can add 100% possible load to a residential circuit in most cases
I've run my christmas display at 90%+ load on a circuit for over 5 hours
--new wiring, breakers...everything
Old 04-29-2010, 10:13 AM   #6
Rewards Points: 1,016
A couple differing schools of thought here...
  • Having a seldom accessed refrigerator or freezer on a separate circuit can be good for reliability - something else tripping the breaker does not take out the refrig/freezer.
  • Having it on a circuit shared with lights can be a good thing as it may be more readily noticeable if the circuit is out because one will notice the lights inop.
Old 04-29-2010, 10:39 AM   #7
Rewards Points: 204
Good points. I figured that is why they recommend running it on it's own circuit, so nothing else can trip the breaker and possibly ruin your perishables in the fridge.
Old 04-29-2010, 12:51 PM   #8
Rewards Points: 530
I have my fridge on a dedicated 20 amp circuit. They do use more power at start up. As they get some age on them, the comprssor will use even more at startup. And I hate to see lights blink because a circuit may be close to capacity.
Actually, I thought all kitchen appliances were supposed to be on dedicated circuits. I also ran one for the micro wave. Then the wife moved the dang thing!
Old 04-29-2010, 01:17 PM   #9
Rewards Points: 204
This is for my bar kitchen. I have the fridge and 4 can lights, Microwave dedicated 20 amp, Stove dedicated 40 amp, and dishwasher on dedicated 20amp (if I add a garbage disposal it will be on this circuit as well.
Old 04-29-2010, 01:49 PM   #10
joed's Avatar
Rewards Points: 13,298
In Ontario Canada where Mike does most of his work it is REQUIRED to have the fridge on a dedicated circuit.
Old 04-29-2010, 03:02 PM   #11
Rewards Points: 1,534
If the circuit serves receptacles in an unfinished portion of the basement then the circuit needs GFCI protection. Meanwhile GFCI protection is not desired for a refrigerator as a trip may go unnoticed and the 'fridge left without power for a period of time.
Old 07-29-2010, 03:46 PM   #12
57_Hemi's Avatar
I've always ran a dedicated line for a fridge. I would much rather tap into another existing cct containing receptacles that are rarely used instead of cct where u know a voltage will be drawn 2-3 times per hour to run a compressor....just makes more sense to me.
Besides.... I wanna make sure nothing F's with my cold beer and frozen steaks....lol
DONT MESS WITH THE AND HIS OR HE'LL BE
57_Hemi is offline   Reply With Quote
Whirlpool Fridge Freezer Display Flicker Herts198 Electrical 1 02-27-2010 12:08 PM
Finishing basment...light questions and more. Abs777 Electrical 10 02-19-2010 10:22 AM
Lights flickering between dim and normal wedge22 Electrical 76 04-23-2009 07:35 AM
Fridge, A/c and half of lights suddenly not working Angelaleonard Electrical 9 04-19-2009 05:01 PM
GFCI trip form fridge jamiedolan Electrical 34 02-06-2009 07:07 AM
