Fridge Compressor - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 02:09 PM   #1
Question
fridge compressor
I want to convert a refrigerator compressor in to a semi power full air compressor is it possible? Also are there any safty precautions i should take during this project. If you have answers on how please respond.
Mufasa02 is offline   Reply With Quote
Old 08-16-2011, 05:17 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,852
It's possible, but probably not worth it unless you have a very special application. Refrigerator compressors have a very low flow rate compared to real air compressors, but are capable of fairly high pressure (300+ PSI). So if you have a need for a small amount of 300PSI air, go for it. Otherwise go buy a cheap air compressor, which will work better.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
Mufasa02 (08-16-2011)
Old 08-16-2011, 05:19 PM   #3
Thumbs up
Ok thank you I'll probably use the refridge compressor than
Old 08-16-2011, 10:47 PM   #4
Idiot Emeritus
Rewards Points: 1,492
It will work, but not for very long. First, a hermetically sealed refrigeration compressor depends on cold refrigerant coming into the suction side for cooling the motor.
Second, some of the oils used in these units don't do well when exposed to oxygen or water vapor. They can become corrosive.
micromind is offline   Reply With Quote
Old 08-16-2011, 11:34 PM   #5
Oh that may pose a problem.
Old 08-17-2011, 02:33 AM   #6
Yeah, reports vary on how long they last. Some say "not very long", others say "plenty long enough". Many people use them as vacuum pumps, too. Either way, you'll need to feed a little bit of oil into the inlet occasionally during operation, because they rely on oil in the refrigerant system to keep the pump lubricated.
Old 08-17-2011, 08:52 AM   #7
Rewards Points: 1,214
It's nothing but trouble just buy one because it won't last long due to the oil problem and freon return for cooling it down. And it's dangerous.
COLDIRON is offline   Reply With Quote
Old 08-17-2011, 09:05 AM   #8
joed's Avatar
Rewards Points: 11,518
I used one for a long time as a compressor to pump up an air tank. It didn't have a lot of use just the occaisional bike tire or small spray job.
Old 08-17-2011, 09:16 AM   #9
Rewards Points: 256
I bought a pancake compressor at Harbor Freight for $30.
I've heard of them used sucsessfully for vacuum setups, but if you are pumping up a car tire ocassionally, I'd buy a cheap one: My time is worth something.
michaelcherr is offline   Reply With Quote
Old 08-17-2011, 05:27 PM   #10
Thank you guys for the advice
Tags
air compressor , refrigerator compressor
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Help assembling compressor jfhspike Tools 5 03-27-2011 11:07 AM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 08:38 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 09:13 AM
Fridge compressor convert to air compressor? jogr Appliances 1 04-24-2008 02:10 PM
