Fridge, A/c And Half Of Lights Suddenly Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2009, 11:54 AM   #1
Post
Fridge, A/c and half of lights suddenly not working
We have lived in our home for 2.5 years and everything has worked fine until this morning. For the last 2 weeks our A/C has been freezing up when used. This morning the Fridge, Microwave A/c and half the lights on one side of our house were not working but no breaker was tripped. now the some of the lights come on dimly and blink on and off. The ventilation fans in hall and bathroom sound as if they are going to come on but they don't get enough power to run. Same thing with the A/C, when we turn it on it sounds like the motor is trying to run but not enough power. Washer and dryer also don't work but the other side of the house is fine. please help
Angelaleonard is offline   Reply With Quote
Old 04-19-2009, 11:58 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 424
Call the power company. It appears you may have lost a leg coming into the home.
Old 04-19-2009, 12:02 PM   #3
Thank you for answering. Are the legs the main breakers on the inside box?
Old 04-19-2009, 12:06 PM   #4
jbfan's Avatar
Rewards Points: 424
Yes. It appears that maybe the wire from the pole, through the meter, into the panel has become loose or completely disconnected.
The power company usually checks for free!
Old 04-19-2009, 01:22 PM   #5
Lights not working and power on and off
We have been having the same problems, our fridge somes on the lights in kitchen start to fail, microwave wants to run but starts and then slows to 1/4 power, when blower on furnace runs it runs at half power. I can the food processer to day and kitchen lights blinked. We have been her 15 years, updated to a breaker box after we bought the house, none of the breakers are overloaded. None have tripped, we have surge protecters at every out let if more than one item is using it. We had new power line installed from the power company to house at same time as breaker box. Two years ago power company installed new lines from their transformer to our house because of break in line, and installed a bigger transformer.
We don't know what could be the problem. Any Ideas.. We hate to have whole house rewired if not necessary.
heavenlyacres is offline   Reply With Quote
Old 04-19-2009, 01:26 PM   #6
jbfan's Avatar
Rewards Points: 424
Do some lights get brighter and some dimmer?
If so, then you have a loose neutral.
You need to call the power company back out and have them check your power again.
The problen could be a lose neutral in the panel box.
Old 04-19-2009, 01:43 PM   #7
Another possibility is your service drop itself. In this area most are aluminum which have a tendency to loosen over time and need to be tightened periodically.
hayewe farm is offline   Reply With Quote
Old 04-19-2009, 01:56 PM   #8
1. Turn your main breaker off and back on.
2. If this doesn't work, call the power company first (it's free). They will tell you if you need to call an electrician.
220/221 is offline   Reply With Quote
Old 04-19-2009, 04:20 PM   #9
Unhappy
Yes some of the lights do dim and then get brighter, the microwave works at one outlet in the kitchen that has nothing else in its breaker. All the problems seem to happen if the fridge is running at the same time. Fridge comes on, microwave slows operation, lights dim, blower on furnace won't run. The range, washer and dryer are on separate circuits and work just fine. The television, dvr, computer do not seem to be affected at all.
Old 04-19-2009, 05:01 PM   #10
joed's Avatar
Rewards Points: 12,464
Light getting brighter are classic symptom of loose neutral.
Call the POCO ASAP. This can cause serious damage to your electronics. The brighter lights are because the voltage is going up.
half the outlet is not working tskmercer Electrical 14 01-17-2009 03:18 PM
16 and a half by 14 and a half feet livingroom. light positioning? fabian Electrical 6 01-11-2009 10:24 PM
Newbie's lights flicker and bulbs blow out MA_in_PC_Fla Electrical 11 05-21-2008 02:34 PM
gas log only half lights wiggs Appliances 1 12-14-2007 07:13 AM
gas fireplce only half lights wiggs HVAC 2 12-13-2007 05:37 PM
