Freeze Protection - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2010, 07:43 PM   #1
Freeze Protection
When it freezes I would like my pool pump to come on. Currently I have it on a mechanical cycle timer.
joselopez is offline   Reply With Quote
Old 11-16-2010, 08:40 PM   #2
joed's Avatar
Rewards Points: 11,534
Use a thermostat. They make them in line voltage versions that should be able to turn on your pool pump.
Old 11-16-2010, 09:20 PM   #3
DIY Home owner
Try one of these...
http://www.lowes.com/webapp/wcs/stor...mostat%20DS100
It's meant for inline heating duct fans, but I use one in my garage inside the soundproof cabinet I built around my air compressor. When it gets hot inside there, this device kicks on the exhaust fan to pull the heat out. It can also be switched to cold temp settings. It's user adjustable so you'll have to play around with the settings to get it to click on and the temp you want. It will, however, run the entire time the temp goes below your setting so you'd have to monitor it.
wherm5150 is offline   Reply With Quote
Freeze protection in utility room? akguy HVAC 1 11-20-2009 06:30 AM
Electrical Baseboard Thermal Protection Blade_316 Electrical 5 10-22-2009 06:51 AM
Whole House Surge Protection? Ultrarunner2017 Electrical 15 02-04-2009 10:39 PM
replace eavestroughs? gutter protection? kianeedshelp Roofing/Siding 4 07-05-2008 10:02 PM
fire protection JustJoe Building & Construction 10 01-27-2007 08:45 AM
