Franklin Pump Cutting Out - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2009, 05:41 AM   #1
Franklin pump cutting out
I'm trying to get a pump working on an old borehole. I've checked the wiring to the control box and pump and made sure its correct. However on turning the pump on, it runs for a minute and a half then the control box clicks out. When you turn it off for a few minutes and start again it does the same thing. My voltage is correct. control box wired in correctly. Can anyone suggest why its doing this?
Thanks craig
CraigZim is offline   Reply With Quote
Old 10-17-2009, 08:45 AM   #2
Rewards Points: 1,440
Does the pump work normally? (Observe the stream of water as pumped onto the ground.)
Is the pump too far below the surface for its strength rating?
Is the outlet pipe or hose too fat (more weight of water to pump up) or too skinny (more friction and resistance)?
Old 10-17-2009, 11:55 AM   #3
Water Well Driller
What your describing is pretty classic symptoms of an overload trip. I'd say the overload is in the controller, but it could be in the motor also. If you only are running it for a short period, I'd say go to the next larger control box and try that. Otherwise, you'll need to find out why it's pulling enough amps to cause the overloads to trip. To clarify - it's not pulling super high amperage - just enough to cause it to trip the overload after a 1.5 minute period.
Also, this whole theory is kaput if you can shut the power and immediately turn it on and start the pump again? If so, I'd look for a faulty pump protection circuit in the system.
piercekiltoff is offline   Reply With Quote
Old 10-17-2009, 12:54 PM   #4
How deep?
Old 10-17-2009, 01:19 PM   #5
Rewards Points: 78
Do you have a way to measure current? Like said above, it may be tripping on overload.
J. V. is online now   Reply With Quote
Old 10-20-2009, 01:27 AM   #6
I will test the pump on the ground. The pump is a .75kw and I think is quite tired. Its has a 50mm pipe and pump has to pump 65m up to ground level. Sorry it sometimes takes a while to reply with all that goes on in my conservancy.
Old 10-20-2009, 01:30 AM   #7
Originally Posted by Yoyizit View Post
How deep?
Pump is down 65 meter.
Old 10-20-2009, 01:32 AM   #8
Could you explain more in depth in how exactly I would measure this. Sorry more mechanically minded than electrical.
Old 10-21-2009, 01:50 AM   #9
" Euro " electrician
frenchelectrican's Avatar
65 meter = 213 feet
And if I did the converson right with KW that is pretty much 3/4 hp motor
Merci.
Marc
Pump Control test Franklin wkosbob Electrical 95 11-26-2016 10:49 PM
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
What should be VOltage Across 2HP 230V Franklin Pump Controller cb1234 Electrical 10 02-17-2011 12:04 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
