Framing Closet Around A Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 08:03 PM   #1
framing closet around a panel
My panel is located in the basement along an outside wall of a finished basement. There is no way to access the panel to add new circuits without ripping down drywall around it.
My question is, is it legal to frame a closet around the panel so I can gain access to all the circuits entering the panel if needed. Nothing but an electrical closet, no clothes or anything else will be in there. I am located in PA if that matters at all.
Thanks,
Keith
polack is offline   Reply With Quote
Old 01-24-2010, 08:18 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
I think you're safe as long as you meet all the proper clearances (someone might be able to chime in with actual numbers) and as long as there's no items that could block it.
Old 01-24-2010, 08:21 PM   #3
As long as you keep the require clerances around the panel & no clothes/combustibles in the closet
Old 01-25-2010, 04:39 AM   #4
Awesome. Thanks a lot. Looks like its going to be bigger than I originally planned.
Old 01-25-2010, 09:19 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
Cut out the sheetrock top and bottom, and make some cabinet doors to cover the openning.
How many times do you think you will need to access the wiring?
Old 01-25-2010, 01:33 PM   #6
Rewards Points: 1,016
The diagram depicts working clearances, not the size of the closet or whatever is built to cover the panel from view.
Old 01-25-2010, 02:27 PM   #7
joed's Avatar
Rewards Points: 11,582
The closet can be small if opening the door give the clearance. It could be just a door or cover right against the wall if you wish.
Infact if you made as big as those clearnaces it probably would no pass. Because then it is big enough for someone to start storing stuff in front of the panel on the floor.
Old 01-25-2010, 02:31 PM   #8
Here is a door someone built to cover a panel:
Old 01-25-2010, 04:08 PM   #9
This is exactly what I want to do. Is this legal?
Old 01-25-2010, 04:19 PM   #10
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
What a freakin ratsnest! aren't there any kind of cable management solutions to clean that up?
brons2 is offline   Reply With Quote
Old 01-25-2010, 08:16 PM   #11
Registered User
Termite's Avatar
Technically, no. The working clearance requirement is taken off the front of the panel and recessing it in a closet like that (with seemingly low headroom) impedes the required working clearance. With a full-height door it would be perfectly legal. It might just be an illusion in the picture though....
Old 01-25-2010, 08:23 PM   #12
Yeah. I'd say its a little on the short side, unless the glass pane door to the left is 8' tall
Use a full size door
Old 01-25-2010, 09:04 PM   #13
Red face
It's not an illusion. I had the same (gut) feeling looking at the (Second set of pictures) It ain't got the (required) clearance.!
spark plug is offline   Reply With Quote
Circuit Breaker Panel Height? helpless handyman Electrical 25 02-24-2014 04:06 PM
Passing wire to another panel theatretch85 Electrical 5 09-21-2009 12:09 AM
120 v circuit from 230 volt panel mills372 Electrical 3 09-07-2009 12:13 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
