Framing Around Panel Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-25-2013, 08:44 AM   #1
Framing around panel box?
Ok,
I am about to run a few more electrical outlets and lights in my closed in garage before attaching drywall.
The wall the panel box is on, the bottom joist is 2 x 6, so I will be adding extra 2 x 4 braces to the wall to bring the drywall even with the raised floor (hope that makes sense).
I can take pictures if needed. My question is, do I have to bring the panel out to be flush with the drywall, or can I "frame" around the panel (plan on hiding it with a large hinged canvas picture) so it can still be accessed and the front removed?
Would it just be easier to move it forward? How is it held to the studs?
GoldenX is offline   Reply With Quote
Old 11-25-2013, 08:46 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,818
We need pictures.
The Following User Says Thank You to ddawg16 For This Useful Post:
plummen (11-25-2013)
Old 11-25-2013, 08:48 AM   #3
Rewards Points: 13,712
It would look a whole lot better to move it forward so the cover sits flush against the drywall.
Should just be screwed to the side of the stud.
Old 11-25-2013, 08:49 AM   #4
Originally Posted by ddawg16 View Post
We need pictures.
Hah, I figured, I will snap a few at lunch!
Old 11-25-2013, 08:50 AM   #5
If that is the case, I may just do that. I just haven't had the cover off yet to see how it is mounted. Just move it up a little and then out as to not disturb any of the wires.
Would probably be a lot less work than framing around it anyways.
Is it required to kill the power before taking the panel cover off, or just best practice?
Old 11-25-2013, 09:03 AM   #6
by code, the face of the panel would need to be flush with the wall.
itsnotrequired is offline   Reply With Quote
Old 11-25-2013, 09:34 AM   #7
To just remove the cover leave it on.
When your working inside to remove the screws and remount, be safe and shut off the breaker supplying power to the panel. And check it with a real meter.
Old 11-25-2013, 12:41 PM   #8
joed's Avatar
Rewards Points: 12,862
AS long as you can remove the cover to work in the panel and the recess is not large enough to be considered a cabinet then you are fine. A panel can not be inside a cabinet where junk can be piled in front of it. You could even build a door in front of it.
Old 11-25-2013, 12:41 PM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Code reference?
The Following User Says Thank You to k_buz For This Useful Post:
brric (11-25-2013)
Old 11-25-2013, 01:37 PM   #10
Originally Posted by k_buz View Post
Code reference?
110.26(A)(2). the width of the working space is measured from the face of the panel. unless this recessed opening is 30" wide, it won't meet code.
don't get me wrong, a panel set a couple inches back into a wall isn't some type of inherently dangerous setup but it is a still a violation.
312.3 might get you a quarter inch recession, depending on the wall material.
Old 11-25-2013, 02:17 PM   #11
k_buz's Avatar
I'll rebut this when I get home.
Old 11-25-2013, 02:25 PM   #12
looking at 110.26, it doesn't explicitly state the width is measured at the face of the panel but it is implied since the depth is measured from there. in any event, 312.3 states it needs to be flush if the wall is combustible or can be set back a quarter inch if not combustible.
Old 11-25-2013, 03:56 PM   #13
k_buz's Avatar
I need a little bit to formulate my argument.
Old 11-25-2013, 04:57 PM   #14
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Is a little bit defined in the code book?
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
k_buz (11-25-2013)
Old 11-25-2013, 05:04 PM   #15
k_buz's Avatar
No, it isn't, and I will have to slowly slunk away in hopes you don't notice me backing out of the discussion. I didn't find what I was expecting to find, so I stand corrected. According to the word of the code, ItsNot is correct.
distribution panel amperage rating tom31415926 Electrical 10 08-26-2012 04:09 PM
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 03:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 10:03 AM
