FPE Electric Panel Replacement - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-05-2009, 11:57 AM   #16
BTW, with the correct panel cover on you can open the door to see the green lights on the surge protector to verify that all is properly functioning. It is flush mounted.
nomad4137 is offline   Reply With Quote
Old 09-18-2009, 01:23 PM   #17
Update: Found another stab-lock refuge! Just realized the upstairs HVAC has a small subpanel with 3 breakers tucked away in a closet. 60 Amp & 20 Amp & a 15.
Is there a retrofit kit for this?? A new HVAC air handler will force me to downsize this 60 Amp anyway.
Old 09-18-2009, 02:48 PM   #18
47_47's Avatar
Rewards Points: 44
Not a pro, but i think a panel is not allowed in a closet.
47_47 is offline   Reply With Quote
Old 09-18-2009, 05:38 PM   #19
These 3 breakers (60,20 & 15) have to be wired to the new CH Loadcenter or there is no way they would currently have power??
Old 09-18-2009, 06:00 PM   #20
What kind of closet?
Clothes closet with clothes hanging in front of it is a big no-no
Old 09-18-2009, 06:27 PM   #21
Yep that kind. What is my best method to fix this?
Can we make this a simple junction?
Old 09-19-2009, 06:45 AM   #22
Code05's Avatar
Rewards Points: 1,104
Correct 240.24(D) states areas such as clothes closets may not have overcurrent/breakers in them.
Code05 is offline   Reply With Quote
Old 09-19-2009, 07:06 AM   #23
Code05's Avatar
If you are asking if you can make this a junction box, than the answer is yes as far as I can tell. No prohibitions in 312 or 314 I could find. Check with your inspector for any local codes. If he says yes, then you can gut the panel, and split bolt,-or what ever method you prefer- to new cables in a different location, attic maybe, and install your sub panel there. Secure the lid to the old cover, put it, and you should be good.
Another thought, can you flip a new panel around in the same location, is the wall in back of the panel accessible?
Old 09-19-2009, 09:37 AM   #24
It is 4-5 feet away from being accessible to the 2nd story attic.
The current headed to this panel has to be coming thru breakers in the CH Panel, therefore they are superflous, correct?
Old 09-20-2009, 07:17 AM   #25
Code05's Avatar
You lost me here. What size breaker feeds this panel? What size wire? What does this panel feed? Where is the new HVAC and what feeds it?
Old 09-21-2009, 12:53 PM   #26
At the present time this panel feeds the furnace in the 2nd story attic.
A new Air Handler will be going up in the attic in fairly short order.
Since this is the old section of the house I am fairly sure it will be a large gauge aluminum wire.
Old 09-22-2009, 02:42 PM   #27
Code05's Avatar
If I am reading all these statements correctly, this is what I am seeing : a 100 amp? panel in a closet with a 2 pole/ double 60 amp breaker, a single pole 15 amp breaker, and a 20 amp pole single breaker. This panel should be fed from the main panel with a 60/70/80/90/ or 100 amp 2 pole breaker. What is the size? Hopefully the feeder cable is 4 wire.What is the size? Now, you mentioned first a furnace(gas or electric?) and then a new air handler( a/c or heat pump with electric back up strips ?). What all do you need to suuply HVAC power? Now, what do these single 15 and 20 amp breakers supply? It still sounds like you need to relocate the panel and I am trying to make sure that the new panel will be adequate to supply your loads.
Old 10-07-2009, 05:48 PM   #28
Code 05
Will try & have answers in short order.
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
Electric panel replacement chris450 Electrical 3 05-30-2008 12:12 PM
Multiple Sub Panel Installation Handyman2007 Electrical 26 12-31-2007 06:47 PM
