Fox & Hound Tips ??? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2009, 07:16 PM   #1
I finally bought one and tried it between 2 new switch locations with multiple wires in each. Neither end is hooked up to the panel yet so theres no ground. So on the first try, the tone was weak. The wires were clearly marked so I knew I was on the right one but was let down with a weak tone and the neighboring wires also carried the same tone.
So any tips or advice on how to use this thing would be appreciated.
II Weeks is offline   Reply With Quote
Old 01-12-2009, 07:24 PM   #2
dSilanskas's Avatar
I have that same tone kit. You have to make sure all the wires on not touching eachother or it will not work right. I love it! works great
dSilanskas is offline   Reply With Quote
Tips for HEAVY sink install Sarah24 Plumbing 3 12-04-2008 07:01 PM
Sanding Tips?????? Dhankins Flooring 3 09-28-2008 11:57 PM
Knock down application tips needed gmhut Painting 1 07-31-2008 09:30 PM
Help :( Looking for tips on fishing PEX between floor joists .. drh HVAC 5 05-29-2008 09:26 AM
Need tips for installing/painting moulding BradG Painting 3 02-04-2008 12:44 AM
