Old 07-26-2014, 09:44 PM   #1
Lord of Slums
Rewards Points: 0
Share |
four recepticles and two ceiling fans
20 amp breaker, 12/2 wire. 4 receptacles daisy chained together, come up to switch then two ceiling fans with no light. All outside on a covered deck. With handrail but no screen or glass. Is this safe, and too code? Would a gfci breaker be the way to go? If I wire a gfci receptacle up stream, can I run the fans off the load side? I am thinking around 75 feet of wire. Is plastic conduit a decent choice as most everything will be exposed.
mj12 is offline   Reply With Quote
Old 07-26-2014, 10:09 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 16
Considered wet location, so 12/2 nm-b wire can not be used.
Take power to switch first, the to first receptacle.
Make the receptacle a WR/GFCI and then use none gfci WR receptacles.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
Old 07-27-2014, 08:02 PM   #3
Lord of Slums
Rewards Points: 0
I read your reply probably 15 times. Now I exactly understand. At first I was just going to listen to your advice, but now I feel like I really learned something. Can not thank you enough.
The Following User Says Thank You to mj12 For This Useful Post:
jbfan (07-27-2014)
Old 07-27-2014, 08:27 PM   #4
jbfan's Avatar
Rewards Points: 16
Some time ,y thoughts and typing do not go hand in hand.
I'm glad you understand what I'm saying.
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
