Found A 2 Gang Box Attached To Drywall Used As Junction. - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2012, 09:32 PM   #1
Rewards Points: 1,452
Found a 2 gang box attached to drywall used as junction.
Just wondering if that's ok. It's a two gang metal box and it's attached to drywall that is in my basement above the joists. The drywall runs all the way up to the subfloor above. It can't use a regular cover so it's open. Looks like they jammed a ground screw in the side. The wiring looks fine, just wondering if there's any reason to change it. I don't want to go through the trouble if it's ok. Thanks.
mikegp is offline   Reply With Quote
Old 08-24-2012, 09:35 PM   #2
Oh, it's attached with two screws through the back of the box.
Old 08-24-2012, 09:57 PM   #3
Master Electrician
It's a hack way to do it. Needs a cover. Get a two gang blank plate. Personally I'd change it.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-24-2012, 09:58 PM   #4
Plastic cover is ok?
Old 08-24-2012, 11:21 PM   #5
Cover
I am trying to picture this whole thing. A photo would explain this a little better.I am picturing a metal box screwed through the drywall into a joist. or something. Regardless a cover is a cover. Plastic or metal whatever you like. Just so you have access the wiring for modification, repair, or inspection. A cover also provides protection to the wiring and people.
bassheadjohn is offline   Reply With Quote
Old 08-24-2012, 11:39 PM   #6
It's on vertical drywall, not horizontal. It's above where the ceiling would be, in the joist cavity. This is up against a garage so the drywall runs all the way up to the subfloor above.
Old 08-25-2012, 07:29 AM   #7
Rewards Points: 3,130
It still needs a cover.
Old 08-25-2012, 12:28 PM   #8
So besides the cover, everything else is acceptable?
Old 08-25-2012, 01:18 PM   #9
Sparky
Rewards Points: 510
as long as its accessible without damaging finished surfaces, yes.
Techy is offline   Reply With Quote
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Ecorock (new green drywall product) Sir MixAlot Drywall & Plaster 0 06-20-2009 08:40 AM
Found mold in the drywall - now what? Rileyhouse Drywall & Plaster 7 03-08-2009 01:16 PM
Single Gang Box used as a Junction? Winchester Electrical 9 09-02-2008 05:33 PM
